06-18-2016, 12:56 AM | #1 |
As seen on TV...
...errr, e-Bay. Ever seen a radius rod dropper? I can't imagine that it would drop the radius rod enough to "increase front axle castor to improve handling and on road stability".
http://www.ebay.com/itm/322151332110...%3AMEBIDX%3AIT |
06-18-2016, 02:10 AM | #2 |
Re: As seen on TV...
cast aluminum....will be destroyed in short order mounting bolts....not set up for the cross pin, you'll never be able to tighten the nylocks an $85 rip off
'31 180A |
06-18-2016, 04:11 AM | #3 |
Did you send your comments to the seller? Wayne
