02-07-2016, 08:45 AM | #1 |
Cotter pins
Hi all. Hardware question:
I opened up the bottom end of my '28 engine. It mostly looks pretty good in there, but some previous owner had the bottom end apart, and used 6-penny nails instead of cotter pins on the rods. Obviously, those need to get replaced I see the parts lists calling for plain steel cotter pins. I have quite a few aircraft grade parts, in stainless. Is it ok to use what I have, or is there a reason to prefer plain steel over stainless for this application? TIA . . . |
02-07-2016, 09:00 AM | #2 |
Re: Cotter pins
I'd think that you'd be fine to use up your stock of stainless cotter pins.....unless you are concerned about the next owner doing what you just did and concluding that some previous owner was a profligate spender. Henry used plain steel because they were adequate and would have been cheaper - if stainless pins were available at all.
02-07-2016, 09:41 AM | #3 |
Re: Cotter pins
He must have been a carpenter.
02-07-2016, 09:50 AM | #4 |
Re: Cotter pins
You don't need cotter pins if the caps are tightened sufficiently.
02-07-2016, 09:59 AM | #5 | |
Re: Cotter pins
02-07-2016, 10:04 AM | #6 |
Re: Cotter pins
02-07-2016, 10:23 AM | #7 |
Re: Cotter pins
Use stainless
02-07-2016, 12:36 PM | #8 |
Re: Cotter pins
If the nails are doing there job, leave them in there. Like the old saying "If it ain't broke, don't fix it"
02-07-2016, 12:39 PM | #9 |
Re: Cotter pins
02-07-2016, 12:50 PM | #10 |
Re: Cotter pins
I've NEVER seen a NAIL fail, when used instead of a cotter key! Years back, they were used a lot, even on the brakes. Folks were POOR. We once lived in a house with a DIRT kitchen floor.
Bill W.
