04-26-2013, 03:05 PM | #1 |
radiator mounting bolt
Does the spring go above or below the crossmember?
04-26-2013, 03:39 PM | #2 |
Re: radiator mounting bolt
Above. I usually put a washer on the bolt, that goes up through the cross member, another washer, the spring, another washer, the nut, and snug it just enough to get the cotter pin through. Might be over kill with the washers, but hey that just me........
04-26-2013, 03:39 PM | #3 |
It goes above the radiator foot.
04-26-2013, 07:09 PM | #4 |
Yo, MrTexas, Dog here, pardner, Ol' Bill would probly put it on the bottom, where it would work O.K, just to drive his "friends" Krazy! Buster T.
04-26-2013, 08:54 PM | #5 | |
With the spring on top the bolt should never move in the crossmember hole. |
