09-25-2020, 09:44 AM | #1 |
Modern OHV Head
I remember about 10 years ago there was a guy who had adapted a modern OHV head to a T block. Has anyone seen what I'm talking about? If so, is there any information and images of the process?
Sent from my SM-N960U using Tapatalk |
09-25-2020, 06:01 PM | #2 |
Re: Modern OHV Head
I recall seeing something along that line, using a more modern head. Even if you find references to it, I don't recall really seeing anything more then it might have been done. If you do a search more then likely you will find information about using a Chevrolet 4 cylinder head from the 20's, not so much about what you might be looking for.
I know the voices aren't real but damn they have some good ideas! |
09-25-2020, 07:07 PM | #3 | |
Re: Modern OHV Head
09-25-2020, 09:30 PM | #4 |
Re: Modern OHV Head
No I do not.
09-25-2020, 10:21 PM | #5 |
Re: Modern OHV Head
We had a guy in the Santa Clara Club that ran a T with one Studebaker V8 head.
09-25-2020, 11:51 PM | #6 |
Re: Modern OHV Head
09-26-2020, 05:47 AM | #7 |
Re: Modern OHV Head
Your looking for a RAJO cylinder head kit, check Chaffin's Garage Corona CA
Hope you have been putting your pennies away, a complete kit is $4,200 and if you go that route go the extra mile and pair that up with a KC Warford transmission. Personally if you want a modern OHV, buy a 5.0 Mustang. |
09-26-2020, 06:26 AM | #8 | |
Re: Modern OHV Head
09-26-2020, 09:56 AM | #9 |
Re: Modern OHV Head
Folks have probably adapted about any ohv head with 4 chambers that has close enough cylinder spacing. It generally always requires a machined adapter plate. The 1921/23 3-port Olds/Chevy heads were the only ones that adapted well back in the day but they would likely be more expensive to purchase and set up than the late reproduction aftermarket stuff.
09-26-2020, 10:41 AM | #10 | |
Re: Modern OHV Head
09-26-2020, 10:54 AM | #11 |
Re: Modern OHV Head
The 3 port Olds looks good, but reports I have seen, does not add all that much. Most guys doing the Chevrolet overhead conversion use the 2 exhaust port 1928 Chevrolet head. Google "MTFCA; poormans RAJO" or "MTFCA; Chevrolet overhead" Are you building a speedster?
The Chevrolet head is not a bolt on and go conversion it requires an adapter plate between the block and head. Unless you can make your own adapter plate or find one, you might be better off just getting one of the high compression heads. I have shared a lot of info on the Model T Ford Club of America as have others. The project has its rewards, pitfalls and takes time, YOU need to be able to figure stuff out and get it all to work together. While the cost still can come in way under a bare RAJO head, it will still cost a good deal more then a good high compression head. If and when you actually take the plunge and get started on this, there are people that can offer advice out there. https://www.youtube.com/watch?v=hiVaPQzH9OM https://www.youtube.com/watch?v=_p40Pd1viO4&t=18s You might want to ask on the Model T Ford Club of America (you need to sign up but do not have to be a member to post) I think you will find more people there that have done stuff like this then here or HAMB.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 09-26-2020 at 05:13 PM. |
09-26-2020, 03:48 PM | #12 |
Re: Modern OHV Head
Thanks for the advice!
09-26-2020, 05:15 PM | #13 |
Re: Modern OHV Head
I have a 1928 Chevy head and rocker arms I will be selling in the near future if your interested.
09-26-2020, 06:06 PM | #14 |
Re: Modern OHV Head
Don't give up , if it is an 'itch' that you just have to scratch !
The fellow who made the great chev four head to A block, died a number of years ago. His creations are sometimes available at swap meets. I've passed on several at Bakersfield. He made a steel plate which made the job easy ! Having had / owned the 4 cyl chev...I would pass for the minimal gain, IMO. But it is an option, eh. I cannot think of the members name, right now, but he is/was on the model A side of Fordbarn. He is a VERY smart engineer type A/B builder for self use. He used a modern V8 head and modified it for use on his model A engines. Made all/everything himself on lathe ! Powerful builds that he raced hill climbs ! Amazing talented guy. You might want to ask there. If his threads still exist, you will learn a LOT. He was not shy at posting pictures of his work...how to, and answering Qs. I'm losing memory and cannot think of these two guys names.... |
09-26-2020, 09:43 PM | #15 |
Re: Modern OHV Head
"Having had / owned the 4 cyl chev...I would pass for the minimal gain, IMO. But it is an option, eh."
Not really true. Comparing the stock Chevrolet engine to a T engine with adapter plate and 28 head installed, not the same. A lot depends on how the adapter is machined. Jerns adapters came in different ratios (both T and A), I wish I had kept a file with the info. With the pop up on the T pistons, flat surface of the Chevrolet head, you can do a lot of things with the 1" thick adapter plate (you can go a little thinner), re designing the combustion space. RAJO's may have about the same squash space and some more (not all were made for the speed set, a number of them were sold as improvement for trucks) unless they have been decked with about the same size valves as the Chevrolet. My compression went from about 50 to 75/80 using the one I made, nothing special, just offset holes 3-3/4" in diameter. For a stock crank that gain was ok. Any more then the bottom end would need attention. The 2ed You-tube video is mine. To add; mine was made so the stock T overhead valve type gasket could be used on one side and stock Chevrolet gasket on the other. The water outlet on block and heads don't line up so there is an adapter to take care of that.
09-26-2020, 11:24 PM | #16 |
Re: Modern OHV Head
When you choose a head you must be sure to get one that has an exhaust valve at each end of the head otherwise the Ford cam will always be opening the wrong valve on that one end cylinder.
I suppose you could have a new camshaft made with a firing order to suit the head. I knew a guy that cut the two rear cylinders off a sixties Jaguar head but he never did get two camshafts made to just run four cylinders. |
09-29-2020, 06:48 PM | #17 |
Re: Modern OHV Head
I don’t need more power in my T, I need more reliability.
The flat head and block are fine, just get that coat hanger wire out of the basement and get a crankshaft and some decent rods in there. And put counter weights on the crank so a ton or so can be shaved off the flywheel. Just the way it was the T preformed well enough. A little higher revs and a stronger flywheel flange would be fine for touring around in the city or the country. With or without a Ruckstell |
05-28-2023, 04:31 PM | #18 |
Re: Modern OHV Head
05-29-2023, 01:08 AM | #19 |
Re: Modern OHV Head
See the PM I sent
