09-09-2020, 11:19 PM | #1 |
Fuel Valve Leak Around Threads
Hello,
I have a 1930 Tudor and i decided to replace the fuel valve because it was leaking a little and the inside of the car smelled like gasoline. I replaced the valve with a nice new one. The problem I have is that I tightened it as tight as I thought it should go....I did not want to split the fitting on the tank....and here is my problem....it leaks around the threads. If it wasn't gasoline I would just use pipe tape, but I heard that would quickly deteriorate. ... Is there any type of pipe thread sealing product that can be used with gasoline? ... Thanks... |
