08-30-2020, 07:34 PM | #1 |
Thread - I screwed up
1950 Mercury-shinny new stroker engine - at the bottom of the stock radiator is an drain petcock. As I needi a thermoratic switch to control the new electric fan, I had the radiator shop add a bung to the bottom radiator tank of the same thread as the drain petcock, which they did.
I Amazoned a good looking 170° thermo-switch, learning that 'good looking' isn't a good way to specify threads. I doesn't fit, likely metric. Can someone tell me what the threads are? Like 3/5NPT or some such so I can reorder a proper switch, i.e. one that actually fits. Thanks I'm getting closer to engine swap scheduled for Sept28 - I need to figure out changing the 4bbl Edelbrock carb for throttle linkage to the pass side as its now on the drivers side. Who sells linkages? |
