Old 06-23-2020, 09:05 AM   #1
Jembow
Jembow's Avatar
Default Classic condenser failure?
Did a 60 mile run visiting family Saturday. Cruising up the main road at around 50mph, I sensed a slights misfire. Further on I went to pass a tractor and it was slow to pick up. Long story short, it got progressively worse. The last 5 miles home we're at around 20mph and it would not respond to wide throttle opening.
Next morning it roared down the road.
Jembow is offline   Reply With Quote
Old 06-23-2020, 09:12 AM   #2
RalphM
RalphM's Avatar
Default Re: Classic condenser failure?
I had one fail on me and it just quit all together, no warning, no sputtering, just quit.
RalphM is offline   Reply With Quote
Old 06-23-2020, 09:25 AM   #3
tubman
tubman's Avatar
Either that or the coil.
Old 06-23-2020, 09:34 AM   #4
Kube
Kube's Avatar
Yep, exactly. I'd suggest you swap ONE piece at a time.
Old 06-23-2020, 09:47 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
"Next morning it roared down the road."
I believe he got her figured-out! DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 06-23-2020, 09:54 AM   #6
Lawson Cox
Lawson Cox's Avatar
Coil. Whwn they cool down, many times they work fine until they get hot again.
condensers generally just crap out. Period. My 2¢.
Old 06-23-2020, 10:17 AM   #7
philipswanson
Glad Skip did my coil. Good piece of mind if nothing else.
philipswanson is offline   Reply With Quote
Old 06-23-2020, 10:44 AM   #8
V8ER
Definitely coil. Works when cool; fails when hot. Condenser failure is instantaneous and does not come back.
V8ER is offline   Reply With Quote
Old 06-23-2020, 10:55 AM   #9
50fordcoupeman
50fordcoupeman's Avatar
Exactly what happened to mine too!
50fordcoupeman is offline   Reply With Quote
Old 06-23-2020, 10:56 AM   #10
Kube
Kube's Avatar
I beg to differ. Usually when a condenser fails, it is complete, IE a total fail.
Occasionally they fail "partially" and when that happens, the same symptoms of a failing coil occur.
I agree his issue is probably the coil but still advise one piece be swapped at a time.
Old 06-23-2020, 11:07 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
GUYS …...READ! Jembow is TRYING to 'learn' y'all something about the symptoms of a faulty CONDENSER. He didn't once ask opinions of what we thought was wrong! He made NO mention of a possible COIL problem! He had the car fixed and 'roaring down the road' the next morning! DD
T5 W/TORQUE TUBE
Old 06-23-2020, 11:37 AM   #12
Kube
Kube's Avatar
I don't read hos post that way. Hmmm???
The title to his thread was a question.
In his post, he said nothing about it being repaired, only that it roared down the road the next day.
A faulty coil, once cooled off, will be fine until it gets hot again. You know that. I sure do from a bad personal experience in bad part of town decades ago.
A guy tends to learn quickly when he's in a dangerous situation. But, I digress.
I'm guessing Jembow will weigh back in here. Now I'm especially curious
Hey Coop, there's a chicken dinner riding on this...
Old 06-23-2020, 11:38 AM   #13
tubman
tubman's Avatar
I see no mention of him fixing anything. Most likely, the coil cooled down and started working again (which is typical). Had several not mentioned the coil, he would probably waste a lot of time chasing condensers when the problem was most likely the coil.
Old 06-23-2020, 11:45 AM   #14
V8COOPMAN
V8COOPMAN's Avatar
Well, I like Popeye's! We'll see what Jembow says. Certainly wouldn't be the first time I wuz full of it! DD
T5 W/TORQUE TUBE
Old 06-23-2020, 11:51 AM   #15
Jembow
Jembow's Avatar
I did nothing, it worked next morning when it had cooled down. I have a replacement coil & condenser bought from one of the vendors - it is marked HAI, does that mean it's a Skip coil?
Old 06-23-2020, 12:06 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
NO cock-a-doodle for me tonight! DD
T5 W/TORQUE TUBE
Old 06-23-2020, 12:41 PM   #17
Kube
Kube's Avatar
I also like Popeye's... you can send a certificate
Old 06-23-2020, 02:22 PM   #18
35fordtn
35fordtn's Avatar
HAI, means it is a skip coil that he rebuilt August,2019.
Old 06-23-2020, 04:25 PM   #19
Lawrie
Lawrie's Avatar
Micheal, is there a code in those letters,
Cam followers you sent are fitted , thanks
Lawrie
Old 06-23-2020, 04:31 PM   #20
Jembow
Jembow's Avatar
Thanks 35fordtn, the coil was bought from you via my friend Roger.
