Old 05-26-2020, 12:06 PM   #1
M2M
M2M's Avatar
Question Which modern valve kit and valve guides?
Snyder:
https://snydersantiqueauto.com/Produ...VE-SET-MODERN?
Or Bratton:
https://www.brattons.com/modern-valve-kit.html
Which is the better kit? Valves guides are different, is one better than the other?
M2M is offline   Reply With Quote
Old 05-26-2020, 01:13 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Which modern valve kit and valve guides?
Somebody on here a couple months ago was recommending the Snyder's-type guides with the shoulders, because I think he was saying if you don't use the shoulder type then the spring is a different length than stock, and you have to account for that. Can't find the thread.
Old 05-26-2020, 01:24 PM   #3
kenparker
kenparker's Avatar
The difference in spring length as mentioned is one issue. The other is... The tube type (Brattons) have to be pressed in with time, patience, a press or a hammer and brass driver to protect the guide from flarring. Snyders are press in with yur fingers or thumb - just likek original guides.
I have used both. ken
kenparker is offline   Reply With Quote
Old 05-26-2020, 01:37 PM   #4
M2M
M2M's Avatar
Thanks guys. I forgot to say that I was thinking of using CW Moss valve springs which are longer in length to standard and have a slightly thicker coil wire. Using these springs which guides are better? I guess I should also ask if these springs suitable for these modern valve kits?
Old 05-27-2020, 11:01 AM   #5
Jim Brierley
I'm probably the guy that recommended guides with the shoulder, at the time only Mac's had such guides, but that is no longer true. I stick with that recommendation, the spring remains the correct length, holds the guides in place, and they are easier to install. What's not to like?
Old 05-27-2020, 12:18 PM   #6
alexiskai
alexiskai's Avatar
Oh yeah, you are that guy. Mike's also carries them, I believe.
Old 05-27-2020, 10:37 PM   #7
SteveB31
SteveB31's Avatar
I have used the valve kits we sell, with the straight guides in The 320 engines we have built, and they work very well. They do do in hard, but they work well. Have several engines with more then 20k miles on them and all are still going strong. Never used the ones with the guides with the shoulders on them, so cannot comment on them.
Steve @ Bert’s
SteveB31 is offline   Reply With Quote
