Old 09-24-2018, 08:16 AM   #21
Ronnie Lawson
Ronnie Lawson's Avatar
Default Re: Weber carburetors
20180519_151648.jpg This is my Weber setup.
Ronnie Lawson is offline   Reply With Quote
Old 09-24-2018, 09:04 AM   #22
Corley
Originally Posted by Ronnie Lawson View Post
Attachment 374869 This is my Weber setup.
Can you say "Over Carb'd"? But, great fun and lot's of bling...
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 09-24-2018, 09:08 PM   #23
Ronnie Lawson
The engine has a Eubank cast nodular (ductile) iron model B balanced crank, in a Model A block. Model B cam, inserted bearings, pressurized oil on all bearings, Stipe/Specialty Cam Hi volume oil pump for A/B engine, 25 lb. aluminum flywheel, 1939 Ford transmission with a Borg Warner overdrive. The intake is what I don’t know the manufacture of.
Old 09-25-2018, 12:01 PM   #24
California Travieso
Send a message via Yahoo to California Travieso
Ronnie,
Looks like a fuel pressure gauge on the fuel line. Are you using the standard fuel tank or some other setup?
My wife is afraid of the standard tank up front so I was thinking of using a 32 tank in back with a fuel pump.
David Serrano
California Travieso is offline   Reply With Quote
Old 09-25-2018, 02:49 PM   #25
denis4x4
denis4x4's Avatar
I’m going to jump in here.....using a fuel pressure gauge on both engines. The ‘29 in the avatar has the stock tank and the roadster has a rear tank. The ‘32 tank is the prototype of the Pinto and we know how that turned out!
File Type: jpg 679E8A62-F3D1-42D2-87E7-1204825E1F84.jpg (127.1 KB, 30 views)
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 09-25-2018, 08:40 PM   #26
Ronnie Lawson
The car is a 1929 Town Sedan. It has two fuel tanks. A custom 10 gallon in the rear and the stock 10 gallon in front. It has two fuel pumps one for each tank. I run 2.5 psi on the pressure gauge.
