Old 12-26-2020, 07:47 PM   #1
Dewshan
Default Troubleshooting advice
Hello! Working on getting a 1931 Victoria back on the road. Engine was rebuilt but i dont know much about who did it etc. It does start but runs weak and sputters when you try to rev it. Spark is good, timing is good- have done it many times with nurex wrench. Known working carb was swapped over - did not fix problem. After pulling spark plugs i believe 4th cylinder is not firing- it was perfectly clean. What does everyone think the next thing to check would be? Timing gear to make sure it is indexed correctly. Or valve clearances? I have removed valve cover but have not checked anything yet. Third choice would be take the head off to investigate i guess? I only want to do this as a last resort. I have compression on all cylinders.
Dewshan is offline   Reply With Quote
Old 12-26-2020, 07:58 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Troubleshooting advice
How long has it been sitting not running? could be a bad plug to start! has happened!
www.whidbeymodelaclub.com
Old 12-26-2020, 08:09 PM   #3
Dewshan
Sat for a long time maybe 12years or so. Has new sparkplugs. Moved spark plugs around . #4 always perfectly clean. Has spark
Old 12-26-2020, 08:19 PM   #4
holdover
did you do a compression test on # 4? If no compression I would pull side cover and see if valves are opening and closing.
holdover is offline   Reply With Quote
Old 12-26-2020, 08:29 PM   #5
Dewshan
Yes have compression on all cylinders
Old 12-26-2020, 08:47 PM   #6
29touring
Is the distributor body new? Its rare, but the arm maybe cracked. If you are getting air and fuel, it has to be spark.
29touring is offline   Reply With Quote
Old 12-26-2020, 08:57 PM   #7
Dewshan
Its old ...i am getting spark to #4 when i gap the copper strip. I also have a cut away cap that lets you see spark going to the 4 leads in distributor looks to be working ok. I guess i could pull it and check it out. I have the puller for that.
Old 12-26-2020, 09:16 PM   #8
Jacksonlll
Jacksonlll's Avatar
I bet your problem is an intake air leak. Do the trick with starting fluid before you start taking things apart. Goo luck.
Old 12-26-2020, 09:18 PM   #9
Dewshan
I thought that also... no such luck. Its sealed up
Old 12-26-2020, 09:58 PM   #10
Mulletwagon
Mulletwagon's Avatar
Sticking valves is a high probability. Recommend dripping Marvel Mystery Oil directly into the carb intake at elevated rpm and also puting MMO in the fuel tank (4 oz. for full tank).
Mulletwagon is offline   Reply With Quote
Old 12-26-2020, 11:34 PM   #11
1crosscut
1crosscut's Avatar
You've said you have compression on all 4 cylinders but have you done an actual compression test? If so what are the numbers?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 12-27-2020, 09:44 AM   #12
rocket1
If it sputters when you rev it might be fuel supply.
rocket1 is offline   Reply With Quote
Old 12-27-2020, 10:08 AM   #13
Ed in Maine
I would do the easy things first. Change the condenser. Short each plug in turn with the engine running and confirm it is the only cylinder that is missing. Change the distributer body, it could be cracked. Run the car in the garage in the dark and see if there is any, sparking where it shouldn't (distributer body, coil, down the spark plug to ground). Set points at 0.020) Good luck, Ed
Old 12-27-2020, 10:10 AM   #14
nkaminar
nkaminar's Avatar
I second what Ed said.
It is really hard to diagnose issues over the internet. But it has to be either fuel or ignition. The plugs can be firing during idle but fail when the throttle is opened because of increased pressure. The spark has to overcome the increased pressure. If the compression numbers are good and no vacuum leaks, I would concentrate on the ignition first.
Try to borrow a known good distributor and coil. The symptoms sound like a bad condenser.
You can check the valve timing by bringing the engine to top dead center by using the timing pin then check to see if the valves in number 4 cylinder are off their seats by an equal amount. If they are then the cam timing is good. If not then the cam timing is bad. A fiber optic scope can be used to view the valves or a dental mirror and flash light. But do the ignition swap first.
Old 12-27-2020, 11:19 AM   #15
ArtimusGordon
I agree with post #13 and would also dribble SEAFOAM into the carburetor when running at an increased throttle. Do this ONLY in open area as you will be getting a lot of smoke out the exhaust!
ArtimusGordon is offline   Reply With Quote
Old 12-27-2020, 01:16 PM   #16
Dewshan
Ok i have it in what the timing gear thinks is tdc. Both valves have no gap for a feeler gauge on cyl 4. In tdc these valves have space for the guage. From front to back. 1,2,4,and 6. Valves 3,5,7,8 no room for feeler gauge.
Old 12-27-2020, 01:56 PM   #17
Ruth
So it sounds like you have the valve cover off and all valves are moving? What are the numbers on your compression test?
Have you checked for carbon arcing as suggested in post #13.
Ruth
Old 12-27-2020, 02:29 PM   #18
nkaminar
nkaminar's Avatar
Your cam is timed correctly. If not, one of the valves on cylinder 4 would have a gap where you could stick a feeler gauge. I had initially intended to peek into the spark plug hole, but your method is also correct.
Old 12-27-2020, 02:34 PM   #19
Dewshan
Yes all valves are moving... compression test had it in 50s all cylinders but it wasnt super accurate my tester not the best for large spark plug holes. Was just checking for compression. I dont think this engine was broken in much after rebuild. New coil, changed condenser, have looked at it running in the dark and did not see arcing. In tdc on the timing gear i can not get a feeler gauge in either valve on cyl 4. Is this the problem?
Old 12-27-2020, 02:43 PM   #20
Dewshan
Pulled spark plugs again.... #2 really rich, #4 perfectly clean. Dont think its firing. It is getting spark though.
