04-18-2017, 12:31 PM | #1 |
modela axle keyway
Are there different width keyways on the axles? Im swapping rear ends and noticed key was too narrow for key way.
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
04-18-2017, 12:42 PM | #2 |
Re: modela axle keyway
Some keyways have been worn wider from running the taper with oil on it, or the nut not tight enough.
04-18-2017, 12:57 PM | #3 |
Are you refering to a model a or aa?
04-18-2017, 01:53 PM | #4 |
model a . What should I do, install the key and make sure nut is tight? Check for play?
04-18-2017, 05:42 PM | #5 |
btw
04-18-2017, 07:12 PM | #6 |
04-18-2017, 08:06 PM | #7 |
If it isn't too bad, I would be sure the taper is clean, dry, and smooth, then properly tighten the nut and drive the car.
04-18-2017, 08:13 PM | #8 |
Been out of the Model A restorations for a while now. Does anyone still offer "step keys?" Wider at the bottom to fit oversize axle keyways and standard size to fit the drums.
A good machine shop could make some from key stock and a vertical mill.
Good enough.. Isn't. |
04-18-2017, 08:21 PM | #9 | |
Then use a fairly large pin punch, perhaps 1/4" and a large hammer and "pein" the shoulder of the axle keyslot. Work to either side to "even-out" and center the key in the slot. Start at the big taper and work your way down to the small. You may want to move the c clamp along too. Doesn't have to be perfect. And when I go back together, I bathe everything in Green Loctite (DON'T USE RED) and put it together quickly - and to a final 130 ft-lbs. (torque to 90 then to 130 minimum two steps.) Drive it for a trip to get ice cream and then re-torque to 130. Drive it a week and then re-torque to 130 - or even to 150. Joe K
Shudda kept the horse. |
04-18-2017, 08:21 PM | #10 |
04-19-2017, 05:54 AM | #11 |
Thanks guys, I appreciate your advise
Im putting a Volvo overdrive in the car.
