12-15-2017, 04:54 PM | #1 |
Jim
Sub.. 37 Ford. Can the new front type oil seal be installed with engine still in vehicle ? Or can oil pan be removed with engine installed with to much trouble? Thanks for advice.
12-15-2017, 05:06 PM | #2 |
Re: Jim
Jb, I believe the crank will have to come out.
12-15-2017, 05:15 PM | #3 |
Re: Jim
Afraid of that! Thanks for reply .
12-15-2017, 07:47 PM | #4 |
Re: Jim
The one piece seals I have seen would only require removal of front pulley, timing cover and pan. Crank stays in place. Here is one at Davetatom.com
http://www.davetatom.com/frontseal.htm |
12-15-2017, 10:48 PM | #5 | |
Re: Jim
12-15-2017, 11:41 PM | #6 |
Re: Jim
12-16-2017, 07:56 AM | #7 |
Re: Jim
As I recall in my 52 I installed it as "deuce roadster" stated above with out removing he crank and still in the truck.
That was eleven years ago. I didn't ask anyone if it could be done or not, just went ahead and did it. Isn't that how we all did it as teenagers with our first cars? |
12-16-2017, 08:44 AM | #8 |
Re: Jim
Here is a U tube version.
Get the seal from Speedway and a Speedi Sleeve from a bearing supply company to fit over the original scroll oil slinger. https://www.youtube.com/watch?v=H3kxG1vwGzU |
