Old 11-17-2010, 12:34 AM   #1
EdB
Default 1941 brakes
thinking that there is a post about adding a booster unit to the braking system on a 41-48 vehicle. failed to make a note of that...can someone direct me to it again? won't loose it this time!!
Thanks
EdB
EdB is offline   Reply With Quote
Old 11-17-2010, 12:10 PM   #2
gkgeiger
gkgeiger's Avatar
Default Re: 1941 brakes
Is this the one you are referring to? https://fordbarn.com/forum/showthread...hlight=booster
gkgeiger is offline   Reply With Quote
Old 11-17-2010, 05:11 PM   #3
Richard (EV8G)
Richard (EV8G)'s Avatar
Original 1941 brakes are Lockheed non-self-energizing and have limitations. I
would recommend converting at least the fronts to new Lincoln-Bendix self-energizing brakes. Reason being that the Lockheed brakes for the most part only use the forward shoe to stop when going forward, while the Bendix use both the forward and rearward shoe. This will provide much-improved stopping as compared to the original Lockheeds. Adding a booster to your 41 would be a PITA and require modifications while providing only a "band-aid" solution. Spend the time and $ instead on the Bendix brakes and forget the booster...
Early V8 Garage
Pasadena Roadster Club
Richard (EV8G) is offline   Reply With Quote
