04-10-2013, 04:39 PM | #1 |
1940 Ford Convertible Top Bows
Does anyone know where I can get the special machine bolts and copper spacers for the top bows on the '40 convertible? I have the caps for the rivets. I also need the piece on the passenger side between the top bow and first knuckle. The tab broke off. I believe it is cast aluminum; I'm trying to get mine fixed.
04-10-2013, 05:13 PM | #2 |
Re: 1940 Ford Convertible Top Bows
Got a picture of what you need?? I might have one. Might try Roy Nacewicz for the bolts. When I built mine he didnt have them but that was 17 yrs ago .
04-11-2013, 12:12 AM | #3 |
Ken,
I belive that a company named Totally Stainless in Penn. makes the bolts. I have directed a number of customers to them for top iron bolts for various years and those that I have heard back from seem very satisfied. Roy Nacewicz |
04-11-2013, 11:55 AM | #4 |
Thanks for responding. I will check on the status of the part being repaired, and maybe I can give you a part number.
04-18-2013, 12:36 PM | #5 |
Just got word part can't be repaired, do you have the piece that goes above the passenger side? On the top bow, across passenger side window, first knuckle joint?
04-19-2013, 08:34 AM | #6 |
04-19-2013, 09:50 AM | #7 |
Is it the piece that's made of diecast?
04-20-2013, 12:36 PM | #8 |
This whole piece is about 22-23 inches long. I would buy the whole piece to get it. The part I need is at the knuckle joint. It's riveted to the piece above the window on the passenger side. I need the passenger side. The part number for the driver's side (which is probably one digit off) from the passenger side, is 01A6653109. Would greatly appreciate any help.
Steve |
