Old 09-16-2020, 07:54 PM   #1
updraught
updraught's Avatar
Default About oils
https://youtu.be/IKdhgKUZhPA
A bit about modern oils. For the purist, I know, I know, but you can't get the old stuff...
updraught is offline   Reply With Quote
Old 09-18-2020, 08:18 AM   #2
KGBnut
KGBnut's Avatar
Default Re: About oils
I have to admit, that was fascinating, and I learned a few things. Admittedly, he is talking about today's modern, tight-tolerance engines, and it doesn't apply so much to our 90-year-old engines.
As a kid, always with an old, beat up car, as it started to burn oil the natural thing to do was to change to a thicker oil. I know that in today's modern cars you just don't do that. This helps explain why. I especially liked his explanation on making choices about changing to a different dual viscosity oil.
Thanks for sharing.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 09-18-2020, 08:43 AM   #3
Jack Shaft
The last thing I think about is efficiency,I have a modern car for that.Whats paramount in my view for my A is protection,Viscosity plays a role,but shear and load characteristics are more important to me,its why I use diesel grade engine oils,overkill protection against load failure and shear.
Jack Shaft is offline   Reply With Quote
Old 09-18-2020, 11:34 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
I use 20 W 50 year round in my model A .
Old 09-18-2020, 04:05 PM   #5
Mike Peters
Mike Peters's Avatar
I use the same multi grade diesel rated oil in our Model A that I use in our diesel farm tractors and diesel grain truck. 15-40 weight.
Mike Peters is offline   Reply With Quote
Old 09-18-2020, 04:29 PM   #6
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
My 2019 Porsche Macan calls for 0w-20 oil in the USA and for 5w-30 oil in other markets.
I am thinking the manufacturers now are calling for oil grades to give them a slightly better CAFE (Corporate Average Fuel Economy) in the US and what protects better in other markets.
Not all manufacturer specs are based on what's best for the auto.....IMHO.
I am still trying to decide what oil I wanna run in my 1931 Model A with insert bearings. Probably 20w-50 synthetic sounds good to me though, as I'm in a warm climate with all cold starts over 50 degrees Farhenheit.
fried okra is offline   Reply With Quote
Old 09-18-2020, 05:35 PM   #7
Aretino
Aretino's Avatar
Shell Rotella T1, SAE 30.
Aretino is offline   Reply With Quote
Old 09-18-2020, 05:48 PM   #8
Patrick L.
Patrick L.'s Avatar
Rotella 15-40 in the A and some other stuff.
Mobil 1 5-20 in the everyday vehicles.
Old 09-18-2020, 06:07 PM   #9
Synchro909
Synchro909's Avatar
El Cheapo 20W50 in my As and change at about 1,000 miles - 3,500 miles if I'm on a long tour where the motor is running warm all day. I run a full flow filter.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-18-2020, 11:01 PM   #10
Licensed to kill
Licensed to kill's Avatar
I run Rotella 15-40 in everything except the Solstice and Avalanche. Not because i think there is anything special about Rotella, they took most of the zinc out of diesel oils close to 10 years ago, I use it because I buy in bulk and that's what I use in my diesels. I also use it in the hydraulic system in my sprayer.
Licensed to kill is offline   Reply With Quote
Old 09-19-2020, 10:43 AM   #11
Jeff/Illinois
Jeff/Illinois's Avatar
Kendall GT-1 has ZDDP blended in, it says on the front of the bottle. You can buy it at Farm King for about $4 a bottle. 10W40.
That or add a bottle of ZDDP you can buy from the Model A parts vendors for about 10 bucks and add it to your favorite motor oil.
I've just run Motorcraft 10W30 or 10W40 with a bottle of ZDDP for years. No problems.
Kendall GT1 goes in the '69 Mach
That was a nice video by the way, thanks for posting!!!
Jeff/Illinois is offline   Reply With Quote
