Old 01-22-2020, 12:03 PM   #1
19Fordy
19Fordy's Avatar
Default What size power valve should I use?
I have a Holley 390 4 barrel 4160 carb. List #0-8007.
Standard 1940 3 speed transmission.
No A/C. or any other amenities except vacuum wipers.
1953 Ford V-8 239 cubic in. stock engine.
Vacuum reading at idle is 18.
Jets are #49
What size power valve do you suggest?
The stock Holly came with #51 jets and 6.5 power valve.
However, I read that the recommended power valve should be obtained by dividing the vacuum reading at idle by 2. Is that true? Thanks.
19Fordy is online now   Reply With Quote
Old 01-22-2020, 02:00 PM   #2
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: What size power valve should I use?
What you read is true. And....
"if your divided number falls on an even number, you should select he next lowest power valve number"
By "the book" you'd use a 9 for a power valve, which isn't available.
A 9.5 might be a little aggressive. (Every time the vacuum drops to 9.5 Hg, it's going to open)
You might like the engine more under load before the PV opens, so a lower numbered power valve like an 8.5 or 7.5.
(hook up a vacuum gauge and see where the reading goes as you're driving)
1948F-1Pickup is offline   Reply With Quote
