07-26-2020, 03:31 PM | #1 |
1928 Radiator Shell Lacing
I looked all over the Internet for pics of properly installed shell lacing but couldn't find any. Does anyone have pics? Where does it terminate at the bottoms and how?
07-26-2020, 04:18 PM | #2 |
Re: 1928 Radiator Shell Lacing
Here are a couple of pictures of the early 28 shell lacing. It is simply cut off at the bottom in line with the bottom of the shell.
07-26-2020, 05:18 PM | #3 |
Oh man I'm way off. Any chance you have a pic of the upper side where the other shell to radiator screw goes through? I thought it just all ran on the outside the whole way around. I sure appreciate the pics!
07-26-2020, 06:40 PM | #4 |
I did a search and found this picture.
07-26-2020, 07:13 PM | #5 |
I'm using a reproduction shell it looks different from those.
07-26-2020, 07:38 PM | #6 |
https://modelastore.com/cooling-syst...roduct_id=3785 |
07-26-2020, 08:13 PM | #7 |
My 28 shell is nickel (March)
07-27-2020, 06:18 AM | #8 |
This is the replacement lacing on my June '28 survivor phaeton. I replaced the original lacing a few years ago (it was falling apart), following the method of fixing (rivets) that was used on the original lacing that I was replacing. I trimmed the bottom of the lacing flush with the bottom of the radiator surround. The bottom rivet holds it in place well enough. This is the only picture that I have available now, but could take a better one if you want.
(Pardon the rusty water stain - I've since replaced the rad core, but that's another (disappointing) story.) |
