09-29-2022, 01:23 PM | #1 |
Speedometer for PU ?
Would someone know if speedometers are all the same from 42-47 on Ford pickups (1/2 ton ? Were they used in 1940 standard cars also ?
09-30-2022, 09:34 AM | #2 |
Re: Speedometer for PU ?
The speedometers should be the same in size from 40 standard to the 41 -47 pickups. The gauge faces will have different colors from passenger cars vs commercials. There is also 100 mph and a 60 mph speedometer. Drake made the '40 standard metal gauge faces and the later pickup colors were only done in decals to my knowledge.
10-01-2022, 07:18 AM | #3 |
Thanks TJ for the info. U wouldn't happen to have a good unit laying around would you that you might part with ?
10-01-2022, 09:53 AM | #4 |
Bob, I don't have one, but I'll check around for you.
10-01-2022, 11:24 AM | #5 |
Try Bob's Speedometer, 1-800-592-9673. They have a large stock of speedometer and gauges. They are good to deal with, and have fair prices.
10-01-2022, 11:57 AM | #6 |
