08-07-2023, 02:16 PM | #1 |
34 commercial grille ID?
I recently bought a Bob Drake 34-35 grille shell ornament to fit my 34 pickup grille because the ornament I had didn’t fit right. It didn’t have the curved notch on the bottom tail where it mates against the SS grille trim. The new ornament doesn’t fit right either. It doesn’t appear to be long enough to wrap around the bull nose of the shell. Plus the rad cap (part 46-8100-b) won’t spin into place because of no clearance with ornament.
Can Someone help me by verifying my grille is a 34 pickup or has the bull nose area been modified? |
08-07-2023, 04:53 PM | #2 |
Re: 34 commercial grille ID?
Looks to be 100% 34 commercial to me.
08-07-2023, 05:06 PM | #3 | |
08-07-2023, 07:28 PM | #4 |
08-07-2023, 10:10 PM | #5 |
Many reproductions don't fit like the original parts. Yours is not an isolated case, it's a fairly common complaint. Still, it's better than not having replacement parts at all, so the usual remedy is to rework the repro to fit, sometimes with very good results.
Alan |
08-08-2023, 12:29 AM | #6 |
08-08-2023, 06:27 AM | #7 |
08-08-2023, 10:09 AM | #8 | |
Before assuming the repro part or the grille is the culprit of poor fit (as repros may be "off" or vary, and original parts may be NOS rejects, modified after 80 years, or simply vary. 1. Check the repro ornament to a known "good" grille. Better yet to 2 or 3. 2. Check the grille to a known fitting ornament (finish not important), again, better 2 or 3. Based on results the ornament will be "off" the grille will be "off", or both. If its the ornament then first try for an exchange with Drake, if that does not provide a fix then modify the ornament as Ford38V8 suggests. |
08-08-2023, 02:35 PM | #9 |
Something's off, the emblem stamping doesn't line up with the hole in the front or the join in the trim
08-08-2023, 03:06 PM | #10 |
Here is an original listed on Ebay.The ornament appears to fit correctly
https://www.ebay.com/itm/38549294661...Bk9SR7bE8eu6Yg Closeup side view,second pic shows the raised stamping clearly.The orig poster's grille shell has been altered at the front tip.Hole enlarged and maybe pushed in a bit. Last edited by deuce lover; 08-10-2023 at 02:39 AM. |
08-08-2023, 05:08 PM | #11 | |
08-08-2023, 05:09 PM | #12 |
Look at the backside of the bullnose, you may see hammer dolly marks. The precise contour of a panel is critical when it fits up to another part.
Alan |
08-08-2023, 05:42 PM | #13 |
Alan counsel is right on. Even without alternation, my experience with '32 radiator shells (a fair number) which are similarly shaped is that a NOS die cast trim will fit best on one shell, a Drake reproduction being the best fit on another radiator shell, and a Vintique reproduction being the best fit on another radiator shell even without any evidence of body work repairs on any of those three radiator shells.
08-08-2023, 08:22 PM | #14 | |
08-08-2023, 09:31 PM | #15 |
A '33 PU converted to '34 PU ??? Newc
08-08-2023, 10:53 PM | #16 |
'33 did not have all that extra molding at the top of the shell. They only had a small indent for the tiny blue FORD oval and a thin center bow point. Hardly nothing around the radiator filler cap either. And the '32 shell was straight vertical. 33 and 34 had a slight rake.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
08-08-2023, 11:10 PM | #17 | |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-08-2023 at 11:23 PM. |
08-09-2023, 12:27 PM | #18 |
I have a nos ornament.
08-09-2023, 01:20 PM | #19 |
08-11-2023, 04:17 PM | #20 |
I have a 34 pickup with the original grill shell it is like the one pictchered by petehovie.
BUT. the edges have the factory tiny slotted holes for the screws that slide around in the factory or Drake grill shell surround stainless trim. The shells in the pitchers do not appear to have those holes indicating they are 33s not 34s. I bought the Drake SS trim and it fit like a glove............... |
