Old 11-17-2015, 09:38 AM   #1
rockfla
rockfla's Avatar
Default Left 1932 Engine Tin
Any one have a left engine tin I could get a picture of the Corner where it bolts to the frame (The corner with the Square Nut (Or Caged Nut) on it? I think it the corner closest to the firewall where it bolts to the frame. One that's off the car and photo of both sides please??? I have a tin that's missing that nut so I need to see what it is to repair it!!
Old 11-17-2015, 10:41 AM   #2
DavidG
DavidG's Avatar
Default Re: Left 1932 Engine Tin
RHD or LHD, four or V-8?
Old 11-17-2015, 10:49 AM   #3
rockfla
rockfla's Avatar
Left Hand, US, V8.....Sorry!!!!
Old 11-17-2015, 10:54 AM   #4
DavidG
DavidG's Avatar
Robert,
Regardless of your answer to the question I posed above, none of the '32 pans had a clinch or "D" nut in the rear-most attachment hole, right or left side. The only clinch nuts that were incorporated into the '32 pans, were on the V-8 versions and were directly below where the center hood bumper bracket attaches to the top of the front fenders passing through the frame and into the engine splash pan clinch nut (on the right side for LHD and on the left side for RHD). The threads were 1/4-28.
In other words, the rear-most attachment holes in all of the '32 engine pans were just holes where a separate 1/4-28 x 1/2 hex bolt, lock washer and loose square nut were used for attachment to the chassis frame.
Old 11-17-2015, 10:57 AM   #5
rockfla
rockfla's Avatar
Here is the pan with what appears to be a square hole in the upper corner???
Old 11-17-2015, 11:05 AM   #6
rockfla
rockfla's Avatar
Here is a close up Dave
Old 11-17-2015, 12:36 PM   #7
Pat/Ohio
Pat/Ohio's Avatar
Robert, I don't believe this pan had a "cage" nut at the rear most hole for the driver's side pan. As stated by Dave above, only the right-hand side had a cage nut attached to the pan. Pat
Pat/Ohio is offline   Reply With Quote
Old 11-17-2015, 01:12 PM   #8
jim1932
jim1932's Avatar
Maybe they left the washer off and it cracked around the square nut?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 11-17-2015, 01:22 PM   #9
rockfla
rockfla's Avatar
Dunno, that's why I asked and posted the above pictures, it sure appears that the square hole was originally there. Our 32 is not close at hand to look at ours so that's the reason for the post.
Old 11-17-2015, 01:26 PM   #10
DavidG
DavidG's Avatar
I think that Jim's theory is a good one as the original nuts were 1/2" square.
Both a mid-year and late pan are shown in the photos below. I've no photo handy of the early pan, but it is the same in that regard.
Old 11-17-2015, 02:01 PM   #11
rockfla
rockfla's Avatar
Thank you David and Jim, I will repair with the proper round hole.
Old 11-17-2015, 03:29 PM   #12
jim1932
jim1932's Avatar
I know on the 4 cylinder pans, I have seen cracks around the bolt holes frequently. Mine came out in crescent shaped chunks
Old 10-20-2020, 05:09 PM   #13
d.conrad
d.conrad's Avatar
What's a fair price to pay for a nice pair of V8 pans.
d.conrad is offline   Reply With Quote
Old 10-20-2020, 06:12 PM   #14
DavidG
DavidG's Avatar
If you find a nice, completely intact pair of '32 V8 engine splash pans for $400, that would be at the low end of the range of what they sell for (which is not often as they were often discarded whenever any service work was done on the exhaust system or starter motor).
Old 10-21-2020, 08:21 AM   #15
Pat/Ohio
Pat/Ohio's Avatar
I believe I paid around $800 for a nice pair of mid-year V8 pans at Hershey 4 or 5 years ago. Was glad to find them!
Old 10-21-2020, 08:31 AM   #16
DavidG
DavidG's Avatar
Pat,
Not at all unheard of; I'm still seeking a right side '33 V8 pan and expect no bargain when one turns up.
