02-01-2012, 11:01 PM | #1 |
Farmer fixes
My grandpa's 30 AA truck has a bunch of farmer fixes
angle iron welded from fender to the running board light switch shutting off all power to car, LOTS OF SOLDER Fenders welded 2 dozen times cowl held on by some make shift bracket Some fixes look like they will never last but some how they did? Post some pictures of your discoveries and unique farmer fixes John |
02-01-2012, 11:15 PM | #2 |
Re: Farmer fixes
I don't have a pic, but when I pulled off the radius rod I noticed the bolts seemed awfully small. When I got all the pieces out it seems someone had dropped a muffler clamp, u-bolt thingy thru the bellhousing and thats what the radius rod was bolted to. Lots of slop etc...I feel MUCH safer after I got all the proper hardware and got rid of the rubber ball as well. Doesn't even shimmy anymore
"Betsy doesn't leak oil - she just marks her spot" |
02-01-2012, 11:35 PM | #3 |
Re: Farmer fixes
I think mostly trucks got these. My 29 AA had quite a few, a modified front axle too self steer behind the cornchopper,a fishplated crossmember in the frame, soldered up gas tank after removing column bracket, only real bad one is they torched the crossmember to get tranny's out for use in a 39. Bob E.
02-02-2012, 12:04 AM | #4 |
Re: Farmer fixes
Don't know if this counts....but my front seat is held together by JB Weld.
Cowtown A's |
02-02-2012, 01:09 AM | #5 |
Re: Farmer fixes
I went over to a clients house a few weeks back, to view a bunch of old car parts strewn about the property.
Some of the pics match this "farmer fix" topic. I wonder what was used to weld the head? Last edited by Craig Lewis; 02-02-2012 at 01:15 AM. |
02-02-2012, 02:36 AM | #6 |
Re: Farmer fixes
02-02-2012, 07:46 AM | #7 |
Re: Farmer fixes
According to a Barner with more knowledge than I have, my 32 BB's fuel pump is a B model bottom with a 34-36 V-8 top. It did work.
Rear fenders and running boards for 1932 131" single wheel Express Body needed. Last edited by Tom H.; 02-03-2012 at 03:54 PM. Reason: info |
02-02-2012, 09:13 AM | #8 |
Re: Farmer fixes
Interesting story's. Keep em coming!
02-02-2012, 11:26 AM | #9 |
Re: Farmer fixes
Some farmer is missing his screendoor spring. |
02-02-2012, 11:34 AM | #10 |
Re: Farmer fixes
I bought a set of 4-21" wheels at the swap meet last year for $20, they look real straight and solid but I won't know till I cut the model T hubs out someone welded in for a long ago project.
02-02-2012, 11:44 AM | #11 |
Re: Farmer fixes
The worst farmer fix I have ever seen was a cheaply fabbed draglink. It cosisted on a piece of pipe which they had ran several strands of number 9 wire through and tightly rapped around the spindle arm ball and the steering arm. I am not sure how far they drove it that way, but it looked dangerous to me. I wish I had my camera with me at that auction where it sold, but I left it home that day. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
02-02-2012, 11:45 AM | #12 |
Re: Farmer fixes
Is this what's meant by "driving by the seat of your pants"? |
02-06-2012, 01:15 PM | #13 |
Re: Farmer fixes
02-02-2012, 11:56 AM | #14 |
Re: Farmer fixes
LOL! Thats a good one Tom. A REAL farmers fix.
Matt from central Jersey |
02-02-2012, 01:33 PM | #15 |
Re: Farmer fixes
Tom, Oshkosh by Gosh is my guess for the overall texture of the patches. Bob
02-04-2012, 04:42 PM | #16 |
Re: Farmer fixes
Some farmer's Model T is missing part of it's running board. |
02-06-2012, 12:51 PM | #17 |
Re: Farmer fixes
I was going to wait until I got my A running again (hopefully in a couple months) and post an album of the many farmer fixes/mods it has but here's a couple samples. The most obvious is the truck mod to the coupe body. Check out the intake manifold, those are castle nuts welded in there and it's setup to mount a Carter W-1 downdraft. The bottom castle nut is for a farmer made check ball that allows excess fuel to drain from the farmer made plenum. Since the Carter W-1 has an accelerator pump this check ball would allow excess gas to drip out of the plenum when starting and prevent flooding, after the engine starts vacuum pulls the check ball closed and seals the vacuum leak. While this looks like a total hack job (and it is) it actually ran quiet well. More to follow.
02-14-2012, 11:11 PM | #18 | |
Re: Farmer fixes
Live your dreams |
03-04-2013, 09:46 AM | #19 |
Re: Farmer fixes
MALAK,
In a point of Model A and/or WWII history, those pickup beds were actually in some cases commercially available. People would install a pickup bed in their car in order to obtain a commercial rating in order to obtain more ration stamps for fuel etc. I have seen these on more cars than Model A's. |
02-06-2012, 01:54 PM | #20 |
Re: Farmer fixes
I for one love these fixes. It gives the car a history and a personality. Plus it just goes to show you how versitile our cars are. Try these fixes on today's and see what happens.
Mike
