Old 05-11-2021, 07:58 PM   #1
Lefthander1930
Lefthander1930's Avatar
Default Window regulator 1932
Has anyone ever tried Or consider Using a 1932 window regulator In a 30-31 Vicky ?? They look the same 6 Hole patten, Can it be done even with some metal work or what ever??
Lefthander1930 is offline   Reply With Quote
Old 05-11-2021, 08:05 PM   #2
SteveB31
SteveB31's Avatar
Default Re: Window regulator 1932
They are similar but not the same, why not use the Correct ones?
SteveB31 is offline   Reply With Quote
Old 05-11-2021, 08:49 PM   #3
Lefthander1930
My old one is broke. Guides on arms are worn & wasted & the Handle mechanism is broken. They don't make all the parts to repair. Ebay prices are out of site.
Old 05-12-2021, 04:23 AM   #4
shew01
shew01's Avatar
Bert’s probably has a good used one for sale at a reasonable price.
shew01 is offline   Reply With Quote
Old 05-12-2021, 06:04 AM   #5
Oldbluoval
Oldbluoval's Avatar
The mounting plate and spacing/ configure are different; won’t work as such
I’ve looked at using the components on the correct plate but never done it
The gears etc are same
I can rebuild most but if u have to use the new winder mech it gets really pricy. I have not been able to interchange the winder component parts with originals very successfully so full assembly required
Oldbluoval is offline   Reply With Quote
Old 05-12-2021, 08:47 AM   #6
Lefthander1930
Thank for your reply. I notice that the mounting holes are different & the plate. I'm going to make templates for both units (Overlays) to see the actual difference
between Them. Cutting & drilling modifying the inner door will be no problem.
(only nuts & bolts) old hot rod saying. I've ordered the regulator & look forward to the challenge. This is what fun about the hobby. Drilling & cutting the inter door skin will nerve show with cover on door.
Old 05-12-2021, 09:20 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
There are no apparent "B" or later window regulators that are similar to those in the 190A. The A-16202-R (left) & A-16203-R (right) are common to the 68C Cabriolet, 160A Standard Fordor, 160B Town Sedan, 160C Deluxe Fordor, 190A Victoria, 295A Town Car Delivery & 400A Convertible Sedan. However, there are a set of "AA" regulators that appear to be the same as A-16202-R & A-16203-R Regulators except that their arms are longer and could be shortened. These are the AA-219204 & AA-219205 used in the 210A AA Panel Delivery, 275A Funeral Coach, 280A Ambulance, 285A Deluxe Police Patrol & 300A Deluxe Delivery.
File Type: jpg 190A RH Window & Door Handle Assembly 672kb.jpg (84.9 KB, 7 views)
Bob Bidonde
