Old 03-25-2021, 09:01 PM   #1
ModelAJim
ModelAJim's Avatar
Default Aftermarket cross channels for subrails need to be cut?
Does anyone know if you need to cut-to-fit the cross channels that go to the subrails you get from Snyder's Bert's ect?
I laid my new subrails out on the floor with the rear subrail where the panel below deck lid bolts too but the cross channels that's seperate the floor pans they seem too long and all same length??
I feel like I have to bolt the subrails to cowl then the rear cross member where panel below deck lid goes then cut the others to width.
Sound right or no?
ModelAJim is offline   Reply With Quote
Old 03-26-2021, 07:14 AM   #2
SteveB31
SteveB31's Avatar
Default Re: Aftermarket cross channels for subrails need to be cut?
They need to be cut.
SteveB31 is offline   Reply With Quote
Old 03-26-2021, 07:26 AM   #3
Oldbluoval
Oldbluoval's Avatar
And the ends bent down on some applications
To be correct
Oldbluoval is offline   Reply With Quote
Old 03-26-2021, 07:45 AM   #4
ModelAJim
ModelAJim's Avatar
Thanks Guys!
Old 03-26-2021, 05:21 PM   #5
gdmn852
gdmn852's Avatar
Hello as mentioned in above post the sub rails will need cut and angles bent on them as they do attach to the side of body also . Try to remove the original and use them as a pattern.You can see where the rails attach in the door dolls and rear wheel well ,they are the round head rivets ,they can be removed by drilling the heads off .
gdmn852 is offline   Reply With Quote
Old 03-26-2021, 05:29 PM   #6
gdmn852
gdmn852's Avatar
Picture of inner door area with rivets ,somewhat ground down Attachment 459545
Old 03-26-2021, 05:35 PM   #7
gdmn852
gdmn852's Avatar
Try again picture
Old 03-26-2021, 05:36 PM   #8
gdmn852
gdmn852's Avatar
Sorry can’t load picture
Old 03-26-2021, 05:52 PM   #9
ModelAJim
ModelAJim's Avatar
Okay actually I don't have any sub-rsils left to compare if someone has a picture of underneath I think I know what you're talking about.
