07-17-2019, 07:07 PM | #1 |
Water temperature sending unit
Where can I get a water temperature sending unit for a 37 21-stud V-8?
Thanking you in advance. Tom |
07-17-2019, 07:35 PM | #2 |
Re: Water temperature sending unit
Dennis Carpenter??
07-17-2019, 08:03 PM | #3 |
From 35-39 the water temperature is measured by a gauge as part of the gauge is the sending unit, they are one assembly. Photo below is 36 temperature gauge.
07-17-2019, 08:14 PM | #4 |
Terry,OH is correct but a '35 and '36 will not fit your original instrument cluster if you are still using it. '37-'39 are the same but the face is different. I have originals or rebuilt ones by Rudy Faultermeir. I would suggest an original since the fluid in rebuilt ones most likely will fade.
07-17-2019, 08:22 PM | #5 |
Williamson's Instruments will put a new bulb on your old gauge.
https://williamsons.com/
Making the simple complicated for over 30 years. |
07-17-2019, 11:31 PM | #6 |
