03-29-2019, 02:29 PM | #1 |
LED lights for 37 Ford
Are LED lights available for a 1937 Ford? If so,
where do I get them? If not, are there other alternatives to get brighter lights? I have a 6-volt system. Thanking you in advance. |
03-29-2019, 04:40 PM | #2 |
Re: LED lights for 37 Ford
They are not car specific. You can find them on E Bay. Make sure they are not polarity specific if you are running a + ground.
03-30-2019, 11:04 AM | #3 |
If you are asking about head lights and they are the original reflector type you will need pre-focused 35-39 bulbs to work with your lens.
If you use the wrong bulbs, LED/halogen with original lens the light is defused all over the place with no actual beam on the road. I would suggest Ron Francis Bright Bulbsm B-2337... Original candle power was 32-32, Bright Bulbs are 125-75.. www.RonFrancis.com 800-292.1940
Bill.... 36 5 win cpe |
03-30-2019, 12:04 PM | #4 |
Isn't that a 12v bulb?
03-30-2019, 09:35 PM | #5 |
Snyders has them in the newest catalog.
03-31-2019, 10:04 PM | #6 |
