03-13-2019, 11:50 AM | #21 |
Re: Radials on a 37. Yes or No??
Coker has wheel liners (strips) to help with that friction.
https://www.cokertire.com/accessorie...im-strips.html I've seen threads were people have suggested duct tape.... |
03-13-2019, 08:53 PM | #22 |
I've been running radials on a 42 front suspension for the past 30 years. The only problem I had with them was: they wouldn't stay on the tracks. Ir was a common practice to drive on the railroad tracks, by lowering the air pressure to 15 lbs on the Bias tires and run down the rails. but the radials keep falling off.
03-13-2019, 08:57 PM | #23 |
A old friend of my pops had a model a that only had wheels (rims) up front (no tires), he used it to pull us on the iced lake with a rope and tube. He had a few "junkers" to mess with. it was a winter setup.
03-13-2019, 09:29 PM | #24 |
I hesitate to say it, but you guys are showing your age.
03-13-2019, 09:40 PM | #25 |
Na. I'm pretty young.
03-14-2019, 09:50 AM | #26 | |
I think the wheel liners are intended for wire spoke wheels and split rims. wheel liners are very common on cycle wheels, motor and bike, because of the spokes.
Bill.... 36 5 win cpe |
03-14-2019, 10:53 PM | #27 |
I think the friction problem between tubeless tires and a tube is from the ribs that run at an angle on the inside of the sidewall on tubeless tires. I have had trouble with those in the past, but never understood how a 'radial tube' solves this. Thicker?? I too have considered radials on my truck based woodie. I do like a fairly tall, narrow tire. A lot of dually pickups came with 225 85r 16s and I wonder about those. Thanks for posting this thread. It has been informative.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-15-2019, 01:35 AM | #28 | |
- Are you sure of this? I don't recall seeing them on any wheels made before sometime in the early 60's. |
03-15-2019, 07:26 AM | #29 |
03-15-2019, 04:11 PM | #30 |
About 10 or 15 years ago the was a lot of talk here about using wheels that were designed for radials. Also the suspension was supposed to be"radial tuned" what ever that was. There was talk of the metal around the lugs failing from fatigue because of flexing causing thd wheel to fall off. Is all that "fake news" now?
04-08-2019, 10:03 PM | #31 |
Running Cooper steel belted radial blackwalls on my 40 wagon on F100 5.5" wide wheels. Stock hub caps even fit as long as you get 66 or earlier F100 wheels. Tires are only $97 a piece. They look and perform great. No Diamondbacks or Cokers for me! Rip off prices.
04-08-2019, 10:25 PM | #32 |
I just switched out the brand bias ply Firestone Deluxe Champions on my '34 truck this weekend.
I switched to Excelsior radials and cannot believe the difference. I might switch to the larger 750 16's on the rear but I am very happy. If you drive your car treat yourself to some radials. |
04-08-2019, 11:04 PM | #33 |
Oohh nice truck... So any difference in steering effort ?
04-08-2019, 11:29 PM | #34 | |
I like the square commercial tires, they look close to bias. Last 2 panel trucks ('54 F100 and '56 Chevy) both had/have 215/85 lt16's on them (the F100 had 16x5 wheels and the Chevy has 16x6). My '47 had really square radials on stock 16x4.5 wheels for years, the '41 pickup has radials not really square so they look so so. After the A is done I'm thinking of bias looking radials, because most regular radials look bulbous and balloony (ie crappy). My '47 had 235/75 r15 wide whites on stock 15x5.5 wheels when i bought it and it looked bad......the 16's with diamondback tires look way better. Last edited by 1oldtimer; 04-08-2019 at 11:35 PM. |
04-09-2019, 11:36 AM | #35 |
