Old 02-16-2018, 11:14 PM   #1
Tom in SW VA
Tom in SW VA's Avatar
Smile Lubricating the commentator
How and where you lubricate the commentator and how often should it done?
Thanks
Tom in SW VA is offline   Reply With Quote
Old 02-16-2018, 11:25 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Lubricating the commentator
Roller type, motor oil every so often thru the oiler hole. Bush or flapper type, no lube. All type should be cleaned maybe once or twice a year or when ignition seems to be to be acting up and does not seem to be the coils.
Old 02-17-2018, 12:31 PM   #3
dumb person
dumb person's Avatar
i fill the flapper full of grease. Roller timers needed oil every 50 miles. Filling one with grease seems to have reduced that but it still likes grease or oil added once a month or it wears.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 02-19-2018, 11:55 AM   #4
Will N
Will N's Avatar
I think that the problem with this board is that too many of the commentators are lubricated .
Will N is offline   Reply With Quote
Old 02-19-2018, 10:15 PM   #5
jetmek
Ha Ha rum and coke is a pretty good commentator lubricant DOH
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 02-22-2018, 05:38 PM   #6
Royce P
Royce P's Avatar
Roller timers get ruined because folks don't lubricate them properly. Ford recommended packing the timer with Vaseline, then oiling it at every gas fill up.
My grandfather tried packing the timer with wheel bearing grease. Our family has found that it works fabulously. Just use either brown or red grease, not the black grease that contains molybdenum which will short out the timer. I try and change the grease every 1000 miles or so. When you do this, there is no wear. None. Car runs great. Easy. Cheap. Simple.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 02-22-2018, 10:19 PM   #7
41panelmark
41panelmark's Avatar
interesting idea Royce. What brand are you using?
41panelmark is offline   Reply With Quote
Old 02-24-2018, 02:01 PM   #8
Royce P
Royce P's Avatar
I buy 5 LB cans of Mobil #28 grease from http://www.skygeek.com
1910 Touring
1914 Touring
1915 Touring
Old 02-24-2018, 06:04 PM   #9
Jack Innes
Jack Innes's Avatar
Royce, This sounds like something worth doing. How much grease do you put in the timer?
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 02-24-2018, 08:20 PM   #10
Royce P
Royce P's Avatar
I pack it with grease.
1910 Touring
1914 Touring
1915 Touring
Old 02-25-2018, 09:26 PM   #11
41panelmark
Royce, I was re reading your first posts and I had a question.
One time recently I could not get my t to start and later after some discussion I realized that I had "over oiled" the commutator. I had to clean it up and put some light oil on the surfaces and put it back together and it ran fine. I was using 80wt trying to achieve something similar to what you have done with grease. So with the grease option if you pack it full of this red grease I assume the the roller pushes things around so that it makes contact anyway. Do I understand this correctly?
Got any photos of how your unit looks when doing this operation?
When it gets hot I am guessing the red grease stays mostly in tact and does not leak all over under the engine?
We use some red grease on semi truck chassis, I am wondering if they are similar to each other.
thanks,
Mark
Old 03-02-2018, 04:18 PM   #12
Royce P
Royce P's Avatar
No, there is little to no leakage of the Mobil 28 grease. I have also used Mobil 1 synthetic automotive grease with equally good results, but I prefer the Mobil 28, perhaps because I occasionally get a free 5 pounder or two that reaches "expiration date" at the airport. They would rather give it away than have to pay for hazmat waste disposal!
I suspect that you are unable to "over oil" a timer. Perhaps you had a starting problem that you attributed to that, but realistically it's not possible. Certainly you can over oil a timer and make a significant mess, but the car would start and run just fine no matter how much oil you put in the timer.
Here's how the inside of a Ford roller timer that lasts forever looks:
thanks,
Mark
1910 Touring
1914 Touring
1915 Touring
Old 03-05-2018, 07:19 PM   #13
41panelmark
Thanks Royce.
Old 11-15-2018, 03:51 PM   #14
lovat
lovat's Avatar
Thanks!
lovat is offline   Reply With Quote
Thread Tools
Display Modes
