Old 04-17-2019, 09:21 PM   #1
JimOH
JimOH's Avatar
Default 1966 Mustang Length
What is the over all length of the 1964-1966 Mustang, front bumper to rear bumper? And get the door closed? Thanks in advance for the answer. JimOH
JimOH is offline   Reply With Quote
Old 04-17-2019, 11:35 PM   #2
Lanny
Lanny's Avatar
Default Re: 1966 Mustang Length
About 15' 5" should be pretty close.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 04-18-2019, 12:37 PM   #3
JimOH
JimOH's Avatar
Lanny, Thanks. I have access to my old Pace that is just over 16' so I am fairly safe there. Now would you be so kind as to tell me the width of these Mustangs? I have about 6'6'' between wheel well covers which I don't think gives me much wiggle room. This trailer was just right for my 32's and A's.
Old 04-18-2019, 12:56 PM   #4
Lanny
Lanny's Avatar
Jim, outside door handle to outside door handle is a tick over 5' 8" across.
Old 04-18-2019, 12:57 PM   #5
50fordcoupeman
50fordcoupeman's Avatar
Google says length is 182" and width is 68".
50fordcoupeman is offline   Reply With Quote
Old 04-18-2019, 01:10 PM   #6
rotorwrench
rotorwrench's Avatar
This links shows 181.6" in length & 68.2" in width. Divide that by 12 for number of feet.
https://itstillruns.com/specificatio...g-6328421.html
Old 04-18-2019, 04:01 PM   #7
Flathead Fever
Flathead Fever's Avatar
That's going to be a tight squeeze. You might need a Mustang convertible with the top down so you can crawl out over the trunk. You could put a door in the side of the trailer wide enough to open the Mustang's driver's door so you could get out of it. You could also push it in backwards so you can grab the front tires and turn them to get it centered in the trailer.
Old 04-18-2019, 06:04 PM   #8
JimOH
JimOH's Avatar
Thanks Lanny, 50fordcoupeman, rotowrench and Flathead Fever.
Can always depend on getting quick answers here. JimOH
Old 04-18-2019, 07:03 PM   #9
Lanny
Lanny's Avatar
You're welcome Jim. Hope you get the 'Stang in there
without too much trouble.
