Old 01-13-2021, 03:40 PM   #1
miskeeta
Default loose venturi
zenith 2 venturi loose in both castings will it work like that
miskeeta is offline   Reply With Quote
Old 01-13-2021, 06:40 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: loose venturi
It is a drop in, so yes, it will not be a press or super tight fit.
Old 01-13-2021, 08:43 PM   #3
miskeeta
thanks
Old 01-14-2021, 04:22 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
On the factory print, the major diameter of the Venturi was specified to be from 1.3732" - 1.3756", -and the minor diameter size was 1.2370" - 1.2430". It really should be a slip fit and not loose as this affects the ability to create a proper vacuum for the jet due to not being centered exactly. Any epoxy (-such as JB Weld) can be your friend if you want to center and fill the void. Use a release agent so the Venturi will not be glued into the housing.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
