Old 12-18-2020, 09:52 PM   #1
28fordroadster
28fordroadster's Avatar
Default Tardell type crossmember plans?
Are there plans or drawings available to make your own member?
28fordroadster is offline   Reply With Quote
Old 12-19-2020, 01:20 AM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Tardell type crossmember plans?
Buy the book how to build a traditional hot rod
Old 12-19-2020, 09:40 AM   #3
1931 flamingo
1931 flamingo's Avatar
What are you wanting to do(modify)??
Some swaps use an F-1 cross member..................
Paul in CT
Old 12-19-2020, 10:29 AM   #4
Jack Shaft
K rail? Tardel fab's them up for A frames..they aint cheap. You putting a flathead in?
Jack Shaft is offline   Reply With Quote
Old 12-20-2020, 12:28 AM   #5
28fordroadster
Yes a flathead 8ba. I don't want to spend alot and I have a good vertical band saw to cut my own parts
Old 12-20-2020, 12:30 AM   #6
28fordroadster
I would be interested in any pictures, links, or info on the F1 xmember
Old 12-20-2020, 09:25 AM   #7
Nosetime
Nosetime's Avatar
Tardel Book and try the Hamb for these questions.
Nosetime is offline   Reply With Quote
Old 12-20-2020, 09:56 AM   #8
rotorwrench
rotorwrench's Avatar
The Bishop/Tardel part only has limited dimensions for the K-member. Ford Motor Co. drawings are available from the Benson Ford research center but may take time due to virus pandemic. The Tardel K-members are basic units that have formed parts welded together to form a member that will work. A lot depends on what the end user wants. If there is no plan of using the 1932 type rear transmission mount, a different design may be in order. This is why some folks opt for a modified F1 cross member. The transmission mount, pedal mounts, and the wishbone mount were the main reason that the 1932 K-member was used to a good extent back in the day. It just made is more simple to go AV8 and add structural rigidity to a weak frame.
This is a link to an old discussion on the subject.
https://www.fordbarn.com/forum/showt...light=K-member
