Old 01-12-2021, 08:41 PM   #1
Dick
Dick's Avatar
Default Clutch chatter solved!
Hi guys,
Wanted to say thanks to everyone one the Barn that has posted about clutch chatter. It was extremely helpful.
Here is what I found:
The throwout bearing should be carefully examined at the point the bearing seats to the base of the hub. It was the issue for my violent chatter. I ended up ordering two more with the bearing on the hub. On one the bearing was cheap junk but on the other the bearing wasn't fully seated to the hub! It was at a slight slant. I bought a USA made bearing from NAPA and had the local mechanic press it on for me. He caught it instantly but his was not tight on one side. He pressed it again and it fit tight and correct
They only seat on the bottom 1/8th of an inch of the bearing and the hub
See the picture. slant at the front of the hub is an optical illusion; its square.
The second is the clutch disc itself. I think quality is the issue and you can see it in the picture. The disc on the right is the Fort Wayne Clutch.
My clutch is smooooth and works perfectly now. What a relief!
I did order another pressure plate from FWC which I installed but it looked exactly like the others so can't say it made a difference. I just don't know.
In conclusion: I would inspect the throwout bearing and hub to be mated correctly and use a USA made TO bearing.
I would buy my clutch parts from Fort Wayne Clutch for best quality
Thanks again guys for all the input; it was invaluable to me!
Dick
Dick is offline   Reply With Quote
Old 01-12-2021, 08:57 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Clutch chatter solved!
I like the disc on the left, it looks well made with flex center, beefier hub attachment, and caged springs. I'm sure both would work OK. It's great you have a good working clutch.
Old 01-12-2021, 09:17 PM   #3
hotcoupe
hotcoupe's Avatar
I had Fort Wayne Clutch rebuild the clutch in my '37 1/2 ton, i couldn't be happier with their work.
Tom
hotcoupe is offline   Reply With Quote
Old 01-12-2021, 11:05 PM   #4
Lawson Cox
Lawson Cox's Avatar
I didn't know a throwout bearing had to be PRESSED on.
News to me, but then I'm only a Shade Tree Mechanic, Third Grade.
Old 01-12-2021, 11:25 PM   #5
GB SISSON
GB SISSON's Avatar
Like Mr. Franklin, I like the one on the left, and I also never had one pressed on. They have all been good over the years, but the one in the woodie chatters badly starting on a hill.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
GB SISSON is online now   Reply With Quote
Old 01-14-2021, 01:33 PM   #6
1948F-1Pickup
1948F-1Pickup's Avatar
Thinner marcel spring on the one on the left. Easy to see that the one on the right
would engage smoother......
1948F-1Pickup is offline   Reply With Quote
Old 01-14-2021, 06:12 PM   #7
cadillac512
cadillac512's Avatar
I agree.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-15-2021, 10:09 AM   #8
G.M.
When I was a kid 75 years ago we swipped a fire xting and
squirted carbon teck in trough the trany inspection plate
and with the front bumper against a tree slipped the clutch.
That usually worked for a while. G.M.
www.fordcollector.com
Old 01-15-2021, 11:29 AM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
I also agree 100% with your assessment. The Fort Wayne on the right is the better choice. I've had at least four sets, of clutch & pressure plates rebuilt by Fort Wayne, and those sets are all now working extremely well in vehicles. I've had several issues with C&PP's coming from off shore manufacturer's. Getting ready to send two more sets of cores to Fort Wayne now.
John
Old 01-15-2021, 05:35 PM   #10
1930ModelA
Years ago I had many aggravating days dealing with chatter and shaking in my ‘36 after installing a new setup from Drake. Took the advise of many who are more knowledgeable than I and bought a C&PP set from Fort Wayne. Absolutely zero problems and years of pleasurable driving after that install. Would never go to anyone else again.
1930ModelA is offline   Reply With Quote
