12-26-2020, 09:54 AM | #1 |
Ford Model A Parts 1928-1931 Fresh list
City:
PICKERINGTON
State:
OH
Price:
in Ad
Ford Model A
30-31 Hood $400 1930 Grill shells (4) $350 each, (4) $275 each, No bottom $175 (2), Needing bottom attached $150 28-29 header crown cap $130 30-31 Firewall $350 (1) $300 (1), One cut out and recessed with bracing $300 28-31 Windshield frame $330 3 of these in stock and one chopped (11 ¾ end measure on chopped one) (plus one more stock $130 rough) 28-31 Radius rods with bungs for hot rod $300 Model a wood header 2.75” by 46.75” $130 each (2) 30-31 visor $130 28-29 visor $100 30-31 dash $95 each (3) 28-29 Roadster seat stiffener brace $75 new 28-31 Murray 4 door window garnish molding 5 pieces missing one of the rear sides $200 28-29 Quarter window garnish $300 28-31 e-brake handle $115 28-29 headlight bars several $90 each 28-29 headlights with outer rings. Pair $125 28-29 bezel with all gauges $230, new chrome $55, one painted and one in original condition -no gauges $30 each 28-29 dash solid $200(1) also one at $150 28-29 coupe reverse chop kit $190 28-29 cut out cowl top $300 OEM 28-29 Cowl top reproduction -no gas hole smooth $300 28-31 Tudor sedan rear quarter window lower garnish set $110 28-31 Back window garnish 4 stock and one with 3’ chop $100 each 28-31 various rear taillight assemblies (4) $80 each 28-31 gas pedal throttle foot assembly and a couple of connection rods $60 and another for $45 28-31 door pull garnish set 27 3/8 long and other side 26 ¾’ L&R one needs shortened $80 28-31 front brake backing plate and some hardware Single l or r $50 28-31 SIDE spare tire mount $50 28-31 REAR tire mount $40 28-31 Tudor front seat swivel mount 1 pair $30 28-31 Lower firewall with feet mounts $300 28-31 Bench seat spring measures 38” long & 18” wide on top & 17” wide on bottom, 7” high in front & 4” in back $100 1931 grill shell $275 (2), No upper panel $175 (1) 20’s-30’s scissor type Emergency brake handles (2) $125 each 30-31 Windshield top frame with hinge $150 SOLID 30-31 door bottom patch new $100 30-31 under visor header panel Fordor, sedan and coupe $100 30-31 Under visor header panel $80 for tudor and pick up 28-31 headlight reflectors pair $75 1930 fender and splash apron section RIGHT $50 28-29 grill shells (2) $100 rusty 30-31 headlight lens $50 Buyer pays shipping. Paypal (friends and family only) or United States Postal Money Order only. Thanks! |
12-31-2020, 07:44 AM | #2 |
Re: Ford Model A Parts 1928-1931 Fresh list
bump
01-14-2021, 10:29 AM | #3 |
bump
01-30-2021, 07:46 AM | #4 |
bump
02-07-2021, 09:16 AM | #5 |
bump
02-14-2021, 10:00 AM | #6 |
02-18-2021, 07:44 AM | #7 |
bump
03-18-2021, 07:32 AM | #8 |
bump
04-29-2021, 03:41 PM | #9 |
bump
