12-18-2020, 09:52 PM | #1 |
Tardell type crossmember plans?
Are there plans or drawings available to make your own member?
12-19-2020, 01:20 AM | #2 |
Re: Tardell type crossmember plans?
Buy the book how to build a traditional hot rod
12-19-2020, 09:40 AM | #3 |
What are you wanting to do(modify)??
Some swaps use an F-1 cross member.................. Paul in CT |
12-19-2020, 10:29 AM | #4 |
K rail? Tardel fab's them up for A frames..they aint cheap. You putting a flathead in?
12-20-2020, 12:28 AM | #5 |
Yes a flathead 8ba. I don't want to spend alot and I have a good vertical band saw to cut my own parts
12-20-2020, 12:30 AM | #6 |
12-20-2020, 09:25 AM | #7 |
Tardel Book and try the Hamb for these questions.
12-20-2020, 09:56 AM | #8 |
The Bishop/Tardel part only has limited dimensions for the K-member. Ford Motor Co. drawings are available from the Benson Ford research center but may take time due to virus pandemic. The Tardel K-members are basic units that have formed parts welded together to form a member that will work. A lot depends on what the end user wants. If there is no plan of using the 1932 type rear transmission mount, a different design may be in order. This is why some folks opt for a modified F1 cross member. The transmission mount, pedal mounts, and the wishbone mount were the main reason that the 1932 K-member was used to a good extent back in the day. It just made is more simple to go AV8 and add structural rigidity to a weak frame.
This is a link to an old discussion on the subject. https://www.fordbarn.com/forum/showt...light=K-member Last edited by rotorwrench; 12-20-2020 at 10:05 AM. |
