Old 10-27-2011, 08:02 PM   #1
hotrodpodo
hotrodpodo's Avatar
Default 1940 Ford spring dimensions...
Hi fellas! I need to know the length of a '40 front spring, eyelet to eyelet on center.
Thanks!
www.DansHotRodPhoto.com
Dedicated to Traditional
Hot Rods & Customs.....
hotrodpodo is offline   Reply With Quote
Old 10-27-2011, 08:19 PM   #2
TJ
TJ's Avatar
Default Re: 1940 Ford spring dimensions...
Do you want the measurement loaded or unloaded?
Old 10-27-2011, 08:29 PM   #3
hotrodpodo
hotrodpodo's Avatar
Unloaded.
Old 10-28-2011, 09:00 AM   #4
TJ
TJ's Avatar
Here's the measurements that I have on an unloaded spring. I have two 40 main leafs and both measure 39 1/4 ctr. to ctr. When you stack the leafs and pull them down with the center bolt the eyes pull inward a little. I suspect that 39 inches(or a little less) may be a true measurement on a fully assembled unloaded spring.
Old 10-28-2011, 09:06 AM   #5
19Fordy
19Fordy's Avatar
I installed a Posie reversed eye spring in my 40 Ford and they called it a "39 inch spring" as suggested by TJ.
Old 10-28-2011, 04:38 PM   #6
hotrodpodo
hotrodpodo's Avatar
Thanks fellas!
