Old 02-23-2020, 04:04 PM   #1
Ragge Jagero
Ragge Jagero's Avatar
Smile Steering Box Ford 1949 sedan
I do need a new steering box to my Ford 1949 sedan V8. Is there any substitute to find?
Ragge Jagero
Lot 107
73393 Sala
Sweden
[email protected]
Ragge Jagero is offline   Reply With Quote
Old 02-23-2020, 04:47 PM   #2
tubman
tubman's Avatar
Default Re: Steering Box Ford 1949 sedan
Are you wanting to keep it stock or are you open to modification? I ask because the car in your avatar seems to be slightly modified and some folks have "upgraded" these to a Volvo box. It might be easier to find than a stock replacement for you.
tubman is online now   Reply With Quote
Old 02-23-2020, 06:05 PM   #3
toby
toby's Avatar
Shoebox Central has a steering box exchange for $625
toby is offline   Reply With Quote
Old 02-23-2020, 06:37 PM   #4
Black Fifty
Black Fifty's Avatar
You could look through this thread that discusses making adjustments to the gear box that might save you from having to purchase new or rebuilt.
https://www.fordbarn.com/forum/showt...+steering+gear
Med Vanliga Halsningar,
Mike
Black Fifty is offline   Reply With Quote
Old 02-23-2020, 06:56 PM   #5
rotorwrench
rotorwrench's Avatar
The worm is usually the first thing to wear out in the OEM 49 thru 51 Ford box. While difficult to replace (a press and some special tooling are needed), the parts are available. An exchange would fix you up if you don't want to do it yourself.
Old 02-24-2020, 12:22 PM   #6
flatheadmurre
flatheadmurre's Avatar
I have the parts on the shelf an hour away from you...you donīt want to rebuild it drop of the box and i rebuild it for you.
Old 02-24-2020, 09:10 PM   #7
Cool Hand Lurker
Cool Hand Lurker's Avatar
WOW! Two guys' located close by each other in Sweden make contact through a guy in USA to solve antique car parts and repair problem!
You can't beat modern tech!
Way to go, FORDBARN !!!!
Cool Hand Lurker is offline   Reply With Quote
Old 02-24-2020, 09:46 PM   #8
tubman
tubman's Avatar
Maybe we should rename this "The Ford Barn Internaionale"!
To the O/P; I would take Murre up on his offer; he is one of the "good guys" and I believe he will be an excellent resource for you.
Old 02-24-2020, 09:49 PM   #9
Newc
Newc's Avatar
'49-51 Steering box mount bolts; Note on some occasions V8' ers have found these three thru-frame bolts to be heavily corroded, Please check yours when possible. Newc
Old 02-24-2020, 10:34 PM   #10
tubman
tubman's Avatar
I have heard this as well. It's worth checking.
