Old 05-29-2019, 10:41 AM   #1
steve40490
Default 49 Custom wheels
I want to buy 15" wheels from a salvage yard to mount radial tires for my 49 shoebox. Anyone know what will fix with correct back spacing ?
steve40490 is offline   Reply With Quote
Old 05-29-2019, 11:36 AM   #2
TJ
TJ's Avatar
Default Re: 49 Custom wheels
I believe the original wheels were 15X5.
Old 05-29-2019, 04:21 PM   #3
toby
toby's Avatar
The back spacing on my stock 15" wheel is 3.5".
toby is offline   Reply With Quote
Old 05-30-2019, 02:57 AM   #4
mercman from oz
mercman from oz's Avatar
This original brochure for the 49 Ford lists the standard wheels as 15" fitted with low pressure 6.70 x 15 Tyres.
Old 05-30-2019, 03:04 AM   #5
mercman from oz
It is interesting to note that the Australian 1949 Fords came with 16" wheels, fitted with 6.00 x 16" 4 Ply Tyres.
Old 05-30-2019, 03:17 PM   #6
fordy_nine
USA-built '49 fords came with 16" wheels and 6.00 x 16" tires on the base model. I believe the wheels are 4" wide. The Deluxe model came with 15" wheels and 6.50 or 6.70 x 15" tires.......Bob L
fordy_nine is offline   Reply With Quote
Old 05-31-2019, 01:15 PM   #7
deuce lover
deuce lover's Avatar
Most any 4.5 " bolt circle will work.Some Mopar 15" from that period will work and are 5" wide.They have clips and take the small hubcap.
deuce lover is offline   Reply With Quote
Old 05-31-2019, 06:43 PM   #8
mfirth
I was advised to buy new wheels from Summit or Wheel Vintique due to salvage wheels being warped, out of round etc. Just my .02 cents.
mfirth is offline   Reply With Quote
Old 05-31-2019, 07:14 PM   #9
aussie merc
aussie merc's Avatar
2nd hand wheels if i buy them i always make sure i can take them back if their buckled easy enough to check just put them on a balance machine without the tyres
aussie merc is offline   Reply With Quote
Old 06-01-2019, 07:46 AM   #10
joe 1950
joe 1950's Avatar
i bought some from a yard that i deal with they were from a 1982 dodge diplomat they were true straight had them sand blasted and painted they worked great being 6 . 5 wide they expand the tire i have 225/75/15 handles and rides great
joe 1950 is offline   Reply With Quote
