01-25-2021, 08:23 PM | #1 |
Ignition cylinder removal
In the process of replacing the original lock cylinder as it only had 1 key. I have removed from housing and it is not obvious how to remove the cylinder itself?
I have a replicate with 2 keys I want to install, any help is appreciated, I have attached a picture, thanks for the help!!
"no one knows more than everyone" |
01-25-2021, 08:37 PM | #2 |
Re: Ignition cylinder removal
I think I would take it to a good locksmith.
01-25-2021, 09:39 PM | #3 |
there is three mounting screw holes for the screws that holds the pop out in the dash panel. in one of them holes it has a spring loaded release that you can get to when the pop out is in the out position. simply put a ice pick in the hole and push it in. it will release the tumbler. note, it will only work if the pop out switch is in the on position.
01-25-2021, 09:42 PM | #4 |
Helpful? I could scan tomorrow if that helps. Bruce
01-26-2021, 06:58 AM | #5 |
Thank guys, just what I needed to see,
Regards
01-26-2021, 11:04 AM | #6 |
of those made in Spain with the weird key. |
01-26-2021, 05:18 PM | #7 |
01-26-2021, 06:00 PM | #8 |
unfortunately, I have been to two reputable lock smiths with the blanks sold from Model A vendors-they could not replicate, I believe the blank we just not correct for the key(#) I had
01-26-2021, 06:08 PM | #9 |
Did you try Dick Crabtree 605-487-7229, if anybody can fix you up he can.
01-26-2021, 07:11 PM | #10 | |
The Town Sedan ignition is not a popout so I know it isn't original. I'll be looking for one when I get to restoring it. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
01-26-2021, 11:27 PM | #11 |
Looking at the picture Brum is posting he is using an aftermarket popout
Very hard for those to find a key. |
01-27-2021, 07:19 PM | #12 |
Yes, Joop that was my realization as well, I did end up buying my replacement for Dick Crabtree
