Old 10-16-2020, 03:21 PM   #1
Superhart
Superhart's Avatar
Default Coupe Glass Replacement
I have a question for you glass experts in Ford Barn Land. I have a 1930 standard Coupe that needs new glass, all except windshield. Does anyone have any idea about the difficulty in removing and replacing the window, quarter and rear window glass on this vehicle? Any comments, suggestions, or lead me in the right direction would be greatly appreciated. Thanks much.
Superhart is offline   Reply With Quote
Old 10-16-2020, 06:46 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Coupe Glass Replacement
Any glass shop should be glad to do the job.
Old 10-16-2020, 07:12 PM   #3
KGBnut
KGBnut's Avatar
Once you pull the interior upholstery panels it is really just a couple of screws to pull out the inner frames of the windows. The only part that I found tricky was stretching the rubber seal around the new windows.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 10-16-2020, 07:16 PM   #4
McMimmcs
McMimmcs's Avatar
I think he was talking do it yourself.
McMimmcs is offline   Reply With Quote
Old 10-16-2020, 07:26 PM   #5
kbinde2
kbinde2's Avatar
I replaced mine in a '29 Coupe, all of the interior material and panels had been removed, so the process was a bit easier. I was also prepping the window garnish mouldings to refinish. If you can salvage the original glass, you have good patterns to take to a glass shop for patterns.
Glass setting material was easy to work with, patience is key, try to keep any seams (joining ends) top center. I used binder clips around the corners of the rear glass to retain shape and keep wrinkles to a minimum. When replacing garnish pieces, tighten the screws evenly around the frame, it's easy to over tighten and stress crack the glass.
Good time to check body wood if not done before. Good luck..kb
I'm sure others will add comment also.. we learn as we do.!
kbinde2 is offline   Reply With Quote
Old 10-16-2020, 08:13 PM   #6
CWPASADENA
CWPASADENA's Avatar
You can buy pre cut glass and the other needed materials from the better parts suppliers if you do not want to involve a glass shop.
This is also a good time to service the window regulators and channels if needed.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-16-2020, 10:16 PM   #7
steve hackel
steve hackel's Avatar
I bought mine from Vintage Glass, 50 Ward Street, Rockville, CT 06066 860-872-0018
It fit great without issues, came packaged in a double industrial box, and they were wonderful to deal with. They also list their items on Ebay, but wanted to give you the direct information.
steve hackel is offline   Reply With Quote
Old 10-17-2020, 09:11 PM   #8
Superhart
Superhart's Avatar
Thanks, Guys. I already contacted Vintage Glass. I was thinking about buying a complete set of their green tinted glass since my vehicle has Vintage Air installed. The existing glass has already had tinting installed but the job quality is exceptionally poor. The regulator in the driver door needs repair or replacement as well as the channels in both doors. I was most concerned about the quarter windows. The interior is already finished so all the panels would need to be removed to do the work. I thought it would just look nicer to put in new tinted glass than just having the existing windows re-tinted. As usual, thanks to all who posted comments.
Old 10-18-2020, 12:01 AM   #9
J Franklin
J Franklin's Avatar
The quarters and back window shouldn't need more than the metal bezels removed to do replacement.
Old 10-18-2020, 07:07 AM   #10
desotoguy
To answer you original question, the difficulty of performing any task relative to a Model A is relative to ones experience, ability and tools to do the job. The quarter windows on the Coupe will be the most difficult as the interior panels will need to be removed and replaced. Take your time and good luck.
desotoguy is offline   Reply With Quote
Old 10-18-2020, 04:05 PM   #11
J Franklin
J Franklin's Avatar
Ok I don't get it. Why do the interior panels need to be removed? I have done this job more than once without any upholstery molestation!
Old 10-18-2020, 04:17 PM   #12
kbinde2
kbinde2's Avatar
I think the original question stated "all except windshield".., leading some to respond with panel advice. It is possible to just unscrew garnish pieces and replace glass.. in my case the interior was being refreshed, to include some wooden pieces, and rework on the door window mechanisms. kb
