Old 07-09-2020, 05:20 PM   #1
LAV
LAV's Avatar
Default Tillotson air balanced 1928-34 carb
This is a new carb and can’t start. Good fuel getting to the inlet of carb, and the gas flows thru valve great but wont start unless I use starter fluid, then runs and stops. New carb, wouldn’t think I’d have to set the float, but out of ideas. Timing is good and fuel is good. Help. Thanks
LAV is offline   Reply With Quote
Old 07-10-2020, 05:03 AM   #2
Wick
Wick's Avatar
Default Re: Tillotson air balanced 1928-34 carb
Air leak. Gasket good between carb and manifold? Engine is pulling air instead of fuel.
That's why the starter fluid works.
Wick is offline   Reply With Quote
Old 07-10-2020, 02:48 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
It does sound like what Wick says . I did have a similar problem with a Tillotson model X . .The air adjust screw had to be just right . Usually one and one half turns on the air adjust screw is normal . I had to fiddle with the air adjust screw to find the sweet spot .
Old 07-10-2020, 03:21 PM   #4
LAV
LAV's Avatar
I have a good gasket and have filed down smooth the the manifold and the carb is new. To eliminate the air leak issue. I don’t think it is an air leak. How do I check float level in Tillotson carb?
Old 07-10-2020, 03:55 PM   #5
Ernie Vitucci
Good afternoon...your air leak could well be between the intake manifold and the block...it has happened to me. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 07-10-2020, 04:09 PM   #6
LAV
LAV's Avatar
Ok, I’ll check that out. Thanks. Any word on how to check float?
Old 07-10-2020, 04:50 PM   #7
Bruce of MN
Bruce of MN's Avatar
This has a tip, not sure where I got it:
Bruce of MN is offline   Reply With Quote
Old 07-10-2020, 05:27 PM   #8
LAV
LAV's Avatar
Thanks so much. This is a real help. I am trying to make sure I eliminate any chance of air leaks fore I do anything else.
Old 07-10-2020, 05:58 PM   #9
Ruth
A friend installed a "new" air-balanced Zenith he got from one of the vendors. We couldn't figure out why it would not run unless the GAV was open 2+ turns and was real hard to start. Even with the GAV open that far, it ran real lean. Plugs were white.
Turns out this "new, made in USA" carb had excessive clearance in the throttle shaft, thus sucking in air. Might want to check your throttle shaft.
Ruth
Old 07-22-2020, 02:58 PM   #10
LAV
LAV's Avatar
Changed gaskets to check for air leaks; did not help.
I slightly adjusted float and now it will start and run (well) for a short time and dies. I have adjusted the GAV (1 full turn) and the air/gas screw (3/4 turn) to the settings on the instruction sheet. Anybody have ideas on how to proceed, without guessing to find the proper settings? Send the carb back? If so are Zenith’s any better? I want to get this one working. Thanks.
Old 07-22-2020, 03:22 PM   #11
wmws
Have you tried taking the full line off and letting at least a pint of gas run out. I'm thinking gas cap vent issue. Or possibly the feral on the gas line is letting the gas line enter too far into the carb thereby slowing fuel supply. I'm not sure if that is relevant on a Tilly.
wmws is offline   Reply With Quote
Old 07-22-2020, 04:39 PM   #12
LAV
LAV's Avatar
Gas into carb is good. Thanks though
Old 07-22-2020, 05:07 PM   #13
Patrick L.
Patrick L.'s Avatar
Was there a problem using the old carb ?
If you choke the heck out of it does the carb throat get wet ?
Ooops, somehow I missed #10. I doubt the problem is float level but its easy to check and adjust. It should set level which should be 1". Adjusting is by bending the float arm carefully.
Tilly's like more GAV opening than Zenith's. Try starting at 1 turn. Idle mix should be as Purdy says, 1.5 turns to start out before adjusting.
Old 07-22-2020, 07:27 PM   #14
LAV
LAV's Avatar
Thanks
