05-09-2020, 06:51 PM | #1 |
1935 rear wishbone shackle bearing removal
any guidance on removing these rubber bearing with center shaft and outer 1/16 steel shell. the old are frozen in place. on one side I managed to remove the center shaft and drill out all the rubber and guts and am only left with the 1/16 thick outer shell. which is rusted in. on the other side I have been pounding on the end of the center shaft with a 5lb mallet for a couple hours it isnt budging. I also saturated everything in kroil on both sides. I thought of getting small increment drills to drill out the one with shell only. a real chore with a half inch drill by hand. please throw any help my way Thanks
Frankie Last edited by stude333; 05-09-2020 at 06:59 PM. Reason: title messed up sorry |
05-09-2020, 06:54 PM | #2 |
Re: [FONT="Arial Black"]1935 rear wishbone shackle bearing removal[/FONT]
Once the centers are out you can remove the outer shell by using a hacksaw blade to carefully cut through the wall and then driving it out. As you are seeing, they are not easy to remove without special tools.
05-09-2020, 06:58 PM | #3 |
Long ago, I'd taken a short center punch, 1/4" diameter and carved out the end to a "half moon". Once you'd pounded out the center, this carved out punch can be set between the metal skin and perch. I use a 2# hammer... the newly carved punch will "split" that thin sheel and peel it away from the perch. Once you have removed it, I'd suggest you run a .750" reamer through there just to be certain there are no burrs, etc. remaining.
Not a fun job but with a little patience and the proper tools, not really all that bad either.
05-09-2020, 06:59 PM | #4 |
Re: 1935 rear wishbone shackle bearing removal
JSeery types a lot faster than me
His method (post #2) is also a good one - tried and true.
05-09-2020, 07:01 PM | #5 |
good tips so far guys i am encouraged....keep em coming
Thanks |
05-09-2020, 07:27 PM | #6 |
05-09-2020, 07:29 PM | #7 | |
Probably the same guys that grind down the outer shell of the new pin so if goes in easier.
05-10-2020, 07:11 AM | #8 |
When it is out-- I then clean up the rusty hole with a piece of emery cloth wound around a piece of round stock with a slit in it to polish up the rusty hole then also polish the outside of the new replacement Pin and use the K R Wilson tool to press the new one in. Hope this helps. kerk
05-10-2020, 07:24 AM | #9 |
The exhaust cutter bit for a “zip gun” will do the job the same as Kube described, as long as you have clearance for the tool.
05-10-2020, 07:31 AM | #10 | |
Then I always finish up with a big 3/4" drill bit and a big drill - and at a very slow speed go through the hole (not taking material out of the perch forging, but cleaning up the bore). These methods have always worked for me. |
05-10-2020, 09:00 AM | #11 |
Adjustable reamer is safer then a drill bit and easier to control
05-10-2020, 12:25 PM | #12 |
If there was rubber inside that means that they were replaced at least once previously as the originals were asbestos cloth lined and the rubber-lined ones were aftermarket. That suggests that careful attention should be paid to making sure there are no burrs in the bore once you remove the steel shell.
05-10-2020, 09:58 PM | #13 |
i blow em out with an oxyacetylene torch after the stud and rubber or whatever is gone. works very well if you are good with a torch. the thin shell heats up so fast that the steel behind it has no chance of even leaving the slightest mark on it . gotta go fast, get all the way thru so you dont have to pre heat again, 2 seconds you're done. i learned from the old junk yard guy how to cut the sides off a nut without wrecking the threads when removing rear axle u bolts. keep the tip clean, keep moving, wonderful tool when you get good at it
05-10-2020, 10:04 PM | #14 |
I had onewith rubber and one with the cloth and grooved shaft. the latter was much harder to remove. but the tips above were my savior. I ended up using a heavy slide hammer on the asbestos one and applying acetylene torch to the hangar body for about 5 minutes. one good whack from the slide hammer and it cam right out! this was after a couple hours of pounding with a 5 lb mallet no avail. then i used my sawzall w/ hacksaw blade to segment the shells and several small chisles & kroil. then finished with a 3/4 drill. Thanks guys...perfecto!!!
