Old 05-03-2020, 06:26 PM   #1
segler
Default Need help lowering roadster top please
We have a new to us 1931 standard roadster and we cannot quite understand how to collapse/lower the top...don't want to bend or damage anything. Any hints appreciated!!
segler is offline   Reply With Quote
Old 05-03-2020, 10:51 PM   #2
jg61hawk
Default Re: Need help lowering roadster top please
First...LOOK around... pretty easy to follow it's path but I understand the question because I too have a Roadster.. The top is "locked in place" at the windshield. Loosen the the locks in the car, not the side windshield wing nuts. Loose the post wing nuts so the top wants to pop up. Then just follow it's natural desire to open. I suspect the top has been up for some time....just gently lift it up...after being sure the little snaps are undone across the windshield.... it will unfold in a very simple manner. Lots of hinges to be sure...WD-40 can't hurt...go slow.....back and forth....go slow...
jg61hawk is offline   Reply With Quote
Old 05-03-2020, 10:52 PM   #3
jg61hawk
Welcome aboard by the way......
Old 05-03-2020, 10:57 PM   #4
jg61hawk
undo something like this so the top pops off the windshield stanchions...that's the first thing... I know I said it before but the wife told me to be more clear.....!!
TOP CLAMPING BRACKET 28-29
A-37323/24-AR
A-37323/24-AR28-29
The bracket on the front corners of the top irons that hold the top to the top of the windshield stanchions. If you are buying new top irons, these are already on them. U.S.A.
Quantity:
1
$58.95 P
Old 05-04-2020, 07:20 AM   #5
Patrick L.
Patrick L.'s Avatar
Once the fasteners across the top of the windshield are off then I have to sit in the middle of the car and push up equally on both sides. Then turn around and keep pushing carefully until its in the down position. All those joints are tight. Mine usually only comes down in the spring and doesn't go back up until it gets put away for the season.
Old 05-04-2020, 09:17 AM   #6
JBill
Just be careful not to "pinch" any of the top material in the irons as they unfold. As Hawk says, go slow.
JBill is offline   Reply With Quote
Old 05-04-2020, 04:52 PM   #7
California Travieso
Send a message via Yahoo to California Travieso
For me, putting the top down or up on my ‘29 Roadster, it’s a lot easier if you make it a two person job. That way, it’s easier to keep from “pinching” the top material. It’s also easier to put the fasteners on at the windshield with two people.
David Serrano
California Travieso is offline   Reply With Quote
Old 05-04-2020, 06:27 PM   #8
Dale G.
Dale G.'s Avatar
I have a question. Why did Ford not put instructions with the car on how to fold and unfold a top on open cars especially a 400A???
Dale G. is offline   Reply With Quote
Old 05-04-2020, 06:34 PM   #9
Synchro909
Synchro909's Avatar
Maybe people didn't need instructions. Fold down tops had been in use for hundreds of years so it was nothing out of the ordinary. Or maybe they were just smarter then.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 05-04-2020, 07:09 PM   #10
segler
Thanks to you all...got it!!!
