05-02-2020, 08:33 AM | #1 |
Oil pump suction?
Just disassembled a Mercury flathead and this is what I found when I removed the pan! Do you think the screen got plugged and the oil pump tried to pull it in? This is a engine with super low miles (19K) but appears to have had lots of short trips. No ring travel, water jackets super clean but the inside gummed up bad.
05-02-2020, 08:38 AM | #2 |
Re: Oil pump suction?
Have you determined what the stuff in the pan is?
05-02-2020, 08:43 AM | #3 |
A little water in the bottom of the pan froze?
"whatever works!" |
05-02-2020, 09:04 AM | #4 |
Yep, the oil pump collapsed it due to the clogging.
05-02-2020, 12:02 PM | #5 |
That is just sludge in the bottom of the pan. I just thought it was interesting, I had never seen that before!
05-02-2020, 01:09 PM | #6 |
05-02-2020, 02:38 PM | #7 |
The swami sez "Non-detergent".
05-02-2020, 03:07 PM | #8 |
The swami knows his sludge.
05-02-2020, 04:51 PM | #9 |
Have no idea it was in the engine when I got it and I never ran the engine.
05-02-2020, 04:52 PM | #10 |
