10-17-2019, 04:21 PM | #1 |
RTH - Crankshaft bearing sizes
Spoke with my machinist today, and he mentioned there was a problem with the crankshaft bearings. Here are the particulars:
1. C69 block (supposedly 100 Hp version) 2. Standard crank (90 Hp version) with reground journals, but not sure of size. 3. Company that reground the crank supplied the bearings to match crank The problem: 1. The crank bearings do not fit the block and main caps. The inside width between the flanges is 0.030" too narrow. 2. Appatently Ford changed the bearing/ block size for 100 Hp rated engines vs. 90 Hp rated engines. 3. They found a set of "correct" bearings in California, but by the time they get here, cost is approx CAN$600! Has anyone had this issue, and if so, what did you do? Machinist is checking with shops to see if it is "customary" to shave the bearings to fit, but this requires building a fixture on a lathe to turn down the thickness of the flanges. |
10-17-2019, 04:41 PM | #2 | |
Re: RTH - Crankshaft bearing sizes
On the earlier blocks they were wider, 2.095" between the flanges. You have the main brg set for an 8BA, it can be machined to fit the early block but it isn't all that easy. Thanks, Gary in N.Y. P.S. You are correct, it would take a bit of "fancy" lathe work with a decent fixture. We've done a few here but only when we couldn't get the right part numbers quick enough!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
10-17-2019, 05:43 PM | #3 |
Thanks very much Gary. So is what you are saying is that they (crank grinder) got a set of bearings for a 8BA type block instead of bearings for a C69 block, and that should be "common"?
10-17-2019, 06:24 PM | #4 |
The C69 engine has a rather uncommon bearing type. I guess that was the result of the change over to full insert bearings for the con rods and all. Canada did it first before Ford USA did but then not all Canadian stuff is the same as USA stuff. The bearings are hard to find now days.
10-17-2019, 09:25 PM | #5 |
Zigg, It'll only be the rear main you need to change. The rear main bearing you require will be #81A- 6331, followed by a letter, which designates the undersize. You'll need to measure your main journal with a micrometer to ascertain what size it's been ground to, and find the appropriate bearing. If you post the measured size, I, or several others on here, can give you the exact part number you'll require.
You'll not need a complete set, so forget about paying $600.00 odd, you'll only need the rear main, and any number of suppliers can provide that.
10-17-2019, 11:30 PM | #6 |
10-18-2019, 01:16 AM | #7 |
Thanks again for all the great info, as not much is available on the interweeb. Sorry, on another forum, we used RTH all the time. It means RealTtine Help. I just assumed it was used here as well. The machinist was supposed to have it wrapped up, but then hit this speed bump, and of course everything stopped until he can figure out what needs to be done.
I should have mentioned he has another engine/ block, and it has the same characteristics as mine, so it is not a one-off type scenario. I wish it was this type of detailed info that should be in every flathead engine build book. Last edited by Ziggster; 10-18-2019 at 01:23 AM. |
10-18-2019, 04:37 AM | #8 |
FWIW the French motors, though they do have some 8BA characteristics do not use the 8BA rear main. 59A type fit.
Mart. |
10-21-2019, 02:58 PM | #9 |
Update: the machinist found the correct bearing at Egge. Some attached pics shaping the difference in rear main bearings. If you look closely you can see the "keyed" section is narrower on the new bearing vs the original. There is a corresponding "notch" in the block.
Original Bearing, |
10-21-2019, 02:58 PM | #10 |
New bearing.
10-21-2019, 03:00 PM | #11 |
Block bearing thickness.
10-21-2019, 03:01 PM | #12 |
Bearing comparison. The original bearing has a wider "notch" compared to the new bearing.
10-21-2019, 03:02 PM | #13 |
I forget to mention that the "new" bearing is the incorrect one.
10-21-2019, 03:16 PM | #14 |
He just bought the wrong year bearings . . . nothing special about your situation, you just need the 39-48 style rear main. All he had to do is look at the bearing tang width in the block and cap - to know he had the wrong one.
IMHO: Since he (or the crank grinder) bought the wrong bearings in the first place, he should be the one who is buying the replacement rear main. To the best of my knowledge, there is no 90HP crankshaft that would have EVER used the bearings the crank grinder supplied . . . so hopefully they're not making some claim along that line. The 49-53 engines all used the 'new' bearing you took pictures of - regardless of displacement or HP ratings. |
10-21-2019, 03:17 PM | #15 | |
10-21-2019, 03:45 PM | #16 |
B&S has it correct....
10-21-2019, 03:51 PM | #17 | |
Re: RTH - Crankshaft bearing sizesr
10-21-2019, 04:41 PM | #18 |
ANY valve in block engine, relieved or not, can be called a flathead, an L head or a sidevalve, all terms relate to the valve in block design.
Some FORD flathead 100 HP blocks were relieved, some weren't. Nothing definitive.... Canadian C69A blocks, as well as SOME other Canadian 85 and 100 HP blocks, used a double drilled throw crankshaft and lock in shell bearings in the rods. The American engines ran exclusively full floaters until the 8BA came out, when they went to lock in 'shell bearings'. The 8BA style of rod bearings/rods, differs from the original lock in bearings/rods used in Canadian pre 8BA assemblies. As the original Canadian lock in bearings are now next to impossible to find, simply use the regular full floaters. They will directly fit.
10-21-2019, 05:21 PM | #19 |
Much appreciated. I think he was saying something to that effect. Figures it would take a Kiwi to educate a Canadian about a C69 engine. So what differentiates the different engines - 85 vs 90 vs 100?
10-21-2019, 06:30 PM | #20 |
Us Kiwi's got our Ford products from Canada- British Commonwealth...hence my familiarity with Canadian engines
The 85-90 HP engines are the 221's 3 1/16 bore x 3 3/4 stroke 100 HP engines are the 239's 3 3/16 bore x 3 3/4 stroke.
