08-19-2019, 09:50 AM | #1 |
fan mix and match
will a 48 fan pulley and generator work on a 38 motor. not sure if the flat surface on the manifold is in the right location for the water pump and generator pulleys to line up. and then can the 48 fan/pulley set up mount such that the crank and fan pulleys will line up. or is some machining/shimming required. thanks for your knowledge.
Frankie |
08-19-2019, 10:32 AM | #2 |
Re: fan mix and match
inner crank pulley goes to water pumps then to generator measure with straight edge, common knowledge: Looks like you are going to a later 35amp and reg system on a 38. Get that dimension right, may have add or mill the late gen housing. Then deal with the fan after: I wouldn't deal with the intake I'd tweak the gen mount. Too bad if you where here, its 20 minutes time for this In our machine shop - for you a member 10 bucks or two beers LOL sp |
