Old 05-20-2019, 08:34 AM   #1
Floats
Floats's Avatar
Default Insert bearings
Hi Gents,
I have looked at the web sites of some of the Model A parts suppliers and it seems as if loose insert conrod bearings are not available. Main bearing inserts are available, however it seems as if conrod inserts only come with NEW conrods and not separate.
Could anyone please shed some light on the subject?
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 05-20-2019, 09:28 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Insert bearings
Check Snyder's. The new rods do not come with bearings you buy the size you need.
https://www.snydersantiqueauto.com/P...onnecting-rods
redmodelt is online now   Reply With Quote
Old 05-20-2019, 11:34 AM   #3
Jim Brierley
Original rods are rough-machined, then babbitted. In order to put inserts in them they must be re-machined to fit the insert, likely just as economical to make new rods and be assured of new parts, old rods often have weak threads.
Jim Brierley is offline   Reply With Quote
Old 05-20-2019, 12:41 PM   #4
d.j. moordigian
d.j. moordigian's Avatar
I believe there are 2 styles,..with and with-out flanges on each side. Post a photo(s)
of your rod bearings...please..
d.j. moordigian is offline   Reply With Quote
Old 05-20-2019, 02:14 PM   #5
Floats
Floats's Avatar
Thanks Gents,
Much appreciated
Regards
Chris
Cape Town
Old 05-20-2019, 04:33 PM   #6
john in illinois
john in illinois's Avatar
Rich Falluca at antique engine rebuilding makes insert rods and could supply you with the correct parts. He has both styles in stock and could answer your questions.
John
Welcome each day
john in illinois is offline   Reply With Quote
Thread Tools
Display Modes
