Old 05-14-2019, 04:29 PM   #1
Ziggster
Default Flathead Main Cap Bolt Lengths - Different lengths?
I have a C69 block and just came back from the machinist and he said the main cap bolts I purchased from Speedway (link below) are too long for the types of main caps that were with my block when I purchased it. He said the shoulders on my caps were shorter than some others he had. Speedway says they are for 32-53. Were there different lengths depending on the year or cap type?
https://www.speedwaymotors.com/ARP-M...ord-V8,17.html
Ziggster is offline   Reply With Quote
Old 05-14-2019, 05:26 PM   #2
34PKUP
34PKUP's Avatar
Default Re: Flathead Main Cap Bolt Lengths - Different lengths?
Originally probably had studs, not bolts.
Good possibility that they can be shortened to make work.
34PKUP is offline   Reply With Quote
Old 05-14-2019, 06:16 PM   #3
flatjack9
flatjack9's Avatar
59AB and back had studs, (48)49 - 53 had bolts.
Old 05-14-2019, 09:41 PM   #4
Ziggster
It's interesting that Speedway advertises the bolts for 32-53 and yet some blocks used studs. He had a block I think from the same year as mine and it had studs. There were no studs in my block when I got it and I'm sure the "originsl" bolts are at the machinists somewhere.
Old 05-15-2019, 09:35 AM   #5
flatjack9
flatjack9's Avatar
The 8BA had 2 different bolt lengths. The center and rear mains used lock washers, so the bolt was slightly longer.
Old 05-15-2019, 03:08 PM   #6
Brian
Brian's Avatar
The C69A block uses bolts, same configuration as flatjack9 describes.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 05-15-2019, 03:43 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Call out for 8BA/8CM looks like 6 bolts (PN B4A-6345-A)
All are (1/2"-13 x 2 7/8" long) and use either 4 or 6 ( 1/2" lock washers)
Old 05-15-2019, 06:03 PM   #8
Ziggster
The Speedway bolts are 3" long and come with hardened flat washers.
Old 05-15-2019, 06:25 PM   #9
Brian
Brian's Avatar
Actually...whenever I build a C69A, I toss the original bolts and fit studs. I prefer studs and safety wire like the earlier engines had. As I result, I've no doubt several sets of original 69A main bearing bolts kicking around. Without hunting them out and examining them, all I can remember is that indeed some positions had spring washers, whilst others didn't, and I think there was two different length bolts used.
Old 05-15-2019, 08:34 PM   #10
flatjack9
flatjack9's Avatar
That may be replacement specs, but originally they were as I posted above.
Old 05-15-2019, 09:25 PM   #11
3twinridges
3twinridges's Avatar
When I put my main caps in, I am pretty sure all of the bolts were the same size, and had lock washers, all 6 of them. However I see in the manual now that the front cap didn’t take lock washers, I wonder why?
Jonathan
3twinridges is offline   Reply With Quote
Old 05-16-2019, 09:05 AM   #12
Ol' Ron
Ol' Ron's Avatar
I noticed that the front bolts have a depression in the center of the head. I use a harden flat washer under the bolt head. Started doing that back in the 60's. not sure why??
Old 05-16-2019, 09:18 AM   #13
Ziggster
Does anyone have a source for the correct bolts or studs?
Old 05-16-2019, 03:58 PM   #14
JSeery
JSeery's Avatar
Well, as I read the Green Book it is not real straight forward.
Studs for 32-36 1/2-13 & 1/2-20 x 3.07
Studs for 37-48 1/2-13 & 1/2-20 x 3.30
BUT, there are also bolts sizes listed, the base stud number is 6345 and it list front, center and rear all the same length.
On the Bolts it list front and rear main as 1/2-13 x 2.72 with a lock washer and the center as 1/2-13 x 3.26 and no listing of a lock washer. The years are a little rumbled up as well. The bolt uses the same base number of 6345. It appears to be a little mixed up to me on the bolt side!
Old 05-16-2019, 04:52 PM   #15
flatjack9
flatjack9's Avatar
Measuring the stock bolts I have, they measure around 3.2 and 2.91. The thickness of the lock washer is .135. That 2.72 measurement is suspect.
Old 05-16-2019, 06:33 PM   #16
Kohnke Rebabbitting
Mr. Ron, with out the hardened flat washer, the hardened lock washer, will dig into the cap, and chew it up some., and even with a normal lock washer, it will do it.
Mr. Ron, you are even more clever then you thought, and can't remember why.
That sounds like a prime example of the saying, of some one forgetting more then other people will ever know!
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 05-16-2019, 06:53 PM   #17
Ziggster
From Reds Vintage Parts
https://reds-vintage-parts.com/red-s...eners-jan-2016
Damn this is confusing.
Old 05-16-2019, 07:03 PM   #18
flatjack9
flatjack9's Avatar
Herm.
Ford did not use flat washers on the main bolts. I have never seen any evidence of galling on the main caps.
Old 05-16-2019, 08:22 PM   #19
Brian
Brian's Avatar
These photos are of original C69A main bearing bolts. They differ in the head configuration; the ones that use spring washers have six slots and a recess, whereas the non washer using bolts have six slightly raised ridges around a raised 'B'. Both bolts measure at 2 15/16" long.
Old 05-17-2019, 02:39 AM   #20
Ziggster
Interesting. Thanks for the pics. I'm going to see if I can drop by the machinist again today to check the lengths of original bolts. I guess the two forward cap studs/bolts didn't use washers so that the bolt heads could clear the oil pan according to the Reds article! The difference between 2-15/16" and 3" in bolt lengths does explain the issue I'm facing as they were closer to 1/4" too long. Do you have pics showing the lengths of the shoulders of the main caps? This is what is likely causing the issue. Seems the Ford "authorized" rebuilders in the day just slapped in whatever worked for them at the time. Lol.
Old 05-17-2019, 05:45 AM   #21
Brian
Brian's Avatar
No, sorry, I have no pictures of main caps. I don't have a C69A apart at this time. As I said in an earlier post, i always fit studs in those blocks anyway.
Old 05-17-2019, 10:32 AM   #22
Ol' Ron
Ol' Ron's Avatar
I;m not that smart. I think Bill Barth told me that. I saw him doing that to a SBC. Also JWL does it aswell. There are allot of smartpeople out there and I just pass it along.
Old 05-17-2019, 04:13 PM   #23
GOSFAST
GOSFAST's Avatar
Just a tip, forget using any bolts, put in a stud kit and be done>
All our builds nowadays get main studs, we put the kits together in-house using all ARP fasteners!
They use .125" thick flat-washers under each nut. We spot-face the original registers on the main cap for a fresh surface!
Thanks, Gary in N.Y.
P.S. Here's a shot of one laid out with the studs, the nice part about the studs we use they can be adjusted in or out up to a .625" or so as needed! The other shot is one with main cap straps included, these studs are just a bit longer O/A however!
GOSFAST is offline   Reply With Quote
Old 05-24-2019, 10:34 AM   #24
Ziggster
Stopped by the machinist this morning. The Speedway/ARP bolts are about 1/4" too long. Also the shoulder just under the head which is a larger dia than the shank interferes slightly with the bore in the cap. The orig bolts have a much larger head and appear to be in good shape, so I'm sticking with them. Lock washers were originally used, but I'll swap out those with the flat washers that came with the new bolts. I'll call Speedway next week to see if they can explain what the issue is.
Old 05-24-2019, 11:24 AM   #25
marko39
On my 51 block the bolts are like the ones you show except the front two are the slotted ones and center and rear that use washers are the other ones and are longer, about 3 1/16. When I took to machinist for alighn honing he told me to leave lock washers off the front cap.
marko39 is offline   Reply With Quote
Old 05-24-2019, 11:42 AM   #26
Ziggster
All the bolts that were on my block (it was rebuilt at some point by a Ford authorized dealer) are like the slotted ones in the attached pic. My machinist and I are still not clear how washers under the two front bolts can interfere with the pan. Looking at the shape of the cap and where the heads of the bolts are located, I can't imagine how the thickness of a washer could cause an issue.
