04-25-2019, 08:30 PM | #1 |
29 Ma steering
Son has a 29 roaster that steers terrible [very hard ] WE have a couple of the later boxes that appear to be ok. He [son] says they do not fit is that so ? or can they be made to fit .Help needed . Johnny.
04-25-2019, 10:15 PM | #2 |
Re: 29 Ma steering
It might be easier to go ahead and fix the steering trouble with the original equipment. A model A can steer quite easily when restored. Other boxes can be made to work, but why?
04-25-2019, 10:15 PM | #3 |
Re: 29 Ma steering
It depends on what the later boxes are. Are they even Ford? If they are Ford the '30-'31 shouldn't be a big problem. The '32 -'36 are a small problem and the '37 and up are a big problem. How about a few pictures of each of the later boxes? My advice would be to rebuild what you have or contact Randy Gross (https://www.fordbarn.com/forum/showt...light=steering) and replace the box with a later truck box.
Charlie Stepehns Last edited by Charlie Stephens; 04-25-2019 at 10:24 PM. |
04-26-2019, 06:31 AM | #4 |
Re: 29 Ma steering
Not to rain on your parade, but you might need more than a steering box restoration.
A correctly redone Model A has very light steering when underway. How are your king pins? I would check over the whole front end. I would also, if possible, rebuild the steering box that is on the car. If to far gone, you most likely also have many other problems that need attention. |
04-26-2019, 09:24 PM | #5 |
Re: 29 Ma steering
Dave / Lincoln Nebraska |
