01-10-2019, 11:31 PM | #1 |
Gasket thickness??
Can someone refresh my memory as to the thickness of compressed Fel-pro and Edelbrock copper/composite gaskets?
Thanks - Fourdy |
01-11-2019, 09:20 AM | #2 |
Re: Gasket thickness??
The last one I measured was .057" for the Fel-pro
01-11-2019, 09:24 AM | #3 | |
The "relaxed" thickness is .062". I would assume any "composite" gasket would also be in this area? Generally speaking you will lose about .004" when torqued-up! Thanks, Gary in N.Y. P.S. Can't help on any Edelbrock gasket dimensions, we don't use that brand here at all.
http://www.stromberg-bulletin.com/me...berg-equipped/ |
01-11-2019, 11:32 AM | #4 |
I checked some Fel-Pro composite gaskets when I was fitting my Edmunds heads and they were also .058 compressed. When you think about it, they should all be designed to end up with the same compressed thickness.
01-11-2019, 12:53 PM | #5 |
I am assuming my other set of "BEST" would be the same? Fourdy |
