Old 09-25-2018, 11:50 AM   #1
f balsiger
Default engine swap
will a model B engine fit in a model A?
f balsiger is offline   Reply With Quote
Old 09-25-2018, 11:55 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: engine swap
Yes, with a few modifications.
Paul in CT
Old 09-25-2018, 05:24 PM   #3
f balsiger
It will bolt up?
Old 09-26-2018, 05:15 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by f balsiger View Post
It will bolt up?
No, as stated above, there are a few mods such as oil pan modifications that would prevent it from being a 'bolt-up' operation.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-26-2018, 08:52 AM   #5
Dave in MN
Dave in MN's Avatar
You need to install a Model A flywheel housing in place of the partial cast iron housing. The rear of the B oil pan needs to be cut off to clear the A flywheel housing. The Model A flywheel inspection cover needs to be modified to fit the larger Model B rear main cap cork seal.
This may sound complicated but it is not.
Good luck with your project.
Good Day!
Dave in MN is offline   Reply With Quote
Old 09-26-2018, 10:17 AM   #6
Charlie Stephens
Here is a picture of a Model B pan cut to go in a Model A. I choose to leave a strap of metal rather than risk a leak by removing spot welds.
Charlie Stephens
