Old 09-04-2016, 09:56 AM   #1
TinCup
TinCup's Avatar
Default Zenith Mod
Working on a Canadian built 31 roadster and when pulling the Zenith 2 carb apart I noticed these mods. Seems to me like I have seen it before but I can't recall where. Is this a modern replacement?
TinCup is offline   Reply With Quote
Old 09-04-2016, 10:11 AM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Zenith Mod
That is a "pressure balanced" carb. The original bowl vent has been plugged and a new path has been machined into the body and venturi to vent the bowl out to the air inlet.
This allows you to run an air filter and not have it make the carb run rich if the filter is a bit restrictive.
HTH.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 09-04-2016, 06:59 PM   #3
Smog Tech
Smog Tech's Avatar
I don't think it was done correctly. The air vent passage should go from the float chamber to after the air cleaner, but before the choke.
Smog Tech is offline   Reply With Quote
Old 09-04-2016, 07:27 PM   #4
C26Pinelake
I am truly impressed with the technical expertise! Wayne
C26Pinelake is offline   Reply With Quote
Old 09-04-2016, 09:18 PM   #5
KMeredith87
KMeredith87's Avatar
That is exactly how mine looks and was done my a man who's name on eBay is tazzmann if I remember correctly. After years of abuse it still runs great, not as good and when i got it from him but still fantastic. Best carb I've ever run on my pick up
KMeredith87 is offline   Reply With Quote
Old 09-06-2016, 10:01 AM   #6
James G.
Smog Tech has it right! (between filter and choke). As said, purpose is to balance out restriction caused by added filter!
James G. is offline   Reply With Quote
Old 09-06-2016, 10:26 AM   #7
Benson
Benson's Avatar
I have one also ... if I understand Smogtech's post?
If you open the choke and look inside at top of the throat, the port is behind the choke plate... that is if you close the choke; the port is behind the plate and not visible.
When I tested it briefly, I noticed that you can close the choke with engine idling and the engine does not stall out.
Benson is offline   Reply With Quote
Old 09-06-2016, 11:23 AM   #8
TinCup
TinCup's Avatar
Is this mod actively being done now for resale or is it a garage mod and by who?
Old 09-06-2016, 12:07 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Renner's Corner pressure balances carbs (and flows jets) altho I don't know if their modification is like this one.
Old 09-22-2016, 02:27 PM   #10
tinkirk
tinkirk's Avatar
Just Talked with Dave Renner and this is how he Pressure Balances the carbs he builds
I Explained to him what i was thinking on how I wanted to do this and, he agreed it is basically the same
Tinkirk/Terry
tinkirk is offline   Reply With Quote
